Up to 20% off select tools
Ryobi RS290G Switch Trigger Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
60
All Time:
682
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 6 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If the switch trigger on your Ryobi RS290G does not power on the tool when engaged, you may be experiencing a failed switch trigger. Switch trigger failures are caused by mechanical failure of the switch or a failed electrical connection. These failures generally occur due to wear or liquid damage.
The switch trigger provides power to the electric motor when the switch is activated. When you engage the trigger, the electric motor will turn on and activate the random orbital motion of the disc. No soldering is required to replace the switch trigger assembly as it is connected to the electronics using spade connectors.
Before starting your switch trigger replacement, make sure the power cable is disconnected.
    1. Ryobi RS290G Switch Trigger Replacement, Top Cap: step 1, image 1 of 1
      • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
      Ask FixBot
    2. Ryobi RS290G Switch Trigger Replacement: step 2, image 1 of 1
      • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
      Ask FixBot
    3. Ryobi RS290G Switch Trigger Replacement: step 3, image 1 of 1
      • Remove the top cap.
      Ask FixBot
    1. Ryobi RS290G Switch Trigger Replacement, Switch Trigger: step 4, image 1 of 1
      • Remove the switch trigger.
      Ask FixBot
Author
with
Kristen Gismondi
110,418 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 60
All Time: 682
