Ryobi RS290G Power Cord Replacement
  1. Ryobi RS290G Power Cord Replacement, Top Cap: step 1, image 1 of 1
    • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
    Ask FixBot
  2. Ryobi RS290G Power Cord Replacement: step 2, image 1 of 1
    • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
    Ask FixBot
  3. Ryobi RS290G Power Cord Replacement: step 3, image 1 of 1
    • Remove the top cap.
    Ask FixBot
  4. Ryobi RS290G Power Cord Replacement, Switch Trigger: step 4, image 1 of 1
    • Remove the switch trigger.
    Ask FixBot
  5. Ryobi RS290G Power Cord Replacement, Power Cord: step 5, image 1 of 1
    • Remove the two 16mm Phillips #2 screws from the inner housing assembly.
    Ask FixBot
  6. Ryobi RS290G Power Cord Replacement: step 6, image 1 of 1
    • Remove the two 14mm Phillips #2 screws from the cord clamp.
    Ask FixBot
  7. Ryobi RS290G Power Cord Replacement: step 7, image 1 of 2 Ryobi RS290G Power Cord Replacement: step 7, image 2 of 2
    • Slide the power switch out of the housing assembly, carefully gripping the switch and pulling it upward.
    Ask FixBot
  8. Ryobi RS290G Power Cord Replacement: step 8, image 1 of 2 Ryobi RS290G Power Cord Replacement: step 8, image 2 of 2
    • Remove the black lead from the power switch using a spudger.
    Ask FixBot
  9. Ryobi RS290G Power Cord Replacement: step 9, image 1 of 1
    • Carefully slide the housing assembly apart, avoiding damage or pulling on wires.
    Ask FixBot
  10. Ryobi RS290G Power Cord Replacement: step 10, image 1 of 2 Ryobi RS290G Power Cord Replacement: step 10, image 2 of 2
    • Slide out the brush assembly with the white lead from the inner housing assembly.
    Ask FixBot
  11. Ryobi RS290G Power Cord Replacement: step 11, image 1 of 1
    • Remove the white lead from the brush assembly.
    Ask FixBot
  12. Ryobi RS290G Power Cord Replacement: step 12, image 1 of 2 Ryobi RS290G Power Cord Replacement: step 12, image 2 of 2
    • Slide the bend relief off of the old power cord to reuse on the new power cord if there is no damage.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Make sure to perform an operational check after reassembling.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 27
All Time: 886
