Introduction
If your Ryobi RS290G bearing assembly is loose or causing traction pad issues, this guide will show you how to successfully replace the bearing assembly.
Using a TR20 Torx security screwdriver, remove the four 6mm screws.
To reassemble your device, follow these instructions in reverse order. Make sure to tighten down properly to avoid loose or traction pad issues.
1 Guide Comment
You show and mention the washer and spring washer at the end but don’t mention in what order you took them off and replace them… probably obvious for most, but not necessarily so for us dunces.
