Ryobi RJ1861V Motor Replacement
  1. Ryobi RJ1861V Motor Replacement, Saw Bar Assembly: step 1, image 1 of 1
    • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
    Ask FixBot
  2. Ryobi RJ1861V Motor Replacement: step 2, image 1 of 2 Ryobi RJ1861V Motor Replacement: step 2, image 2 of 2
    • Remove the rubber sleeve.
    • You may have to use some force as it has a tight fit.
    Ask FixBot
  3. Ryobi RJ1861V Motor Replacement: step 3, image 1 of 1
    • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
    Ask FixBot
  4. Ryobi RJ1861V Motor Replacement: step 4, image 1 of 1
    • Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
    • There are two screws on each side of the device.
    Ask FixBot
  5. Ryobi RJ1861V Motor Replacement: step 5, image 1 of 1
    • Remove the backside panel.
    Ask FixBot
  6. Ryobi RJ1861V Motor Replacement: step 6, image 1 of 1
    • Unscrew the four T5 Torx screws that hold the assembly bar in place.
    Ask FixBot
  7. Ryobi RJ1861V Motor Replacement: step 7, image 1 of 1
    • Lift the assembly bar up and out of the chassis.
    Ask FixBot
  8. Ryobi RJ1861V Motor Replacement, Assembly Bar Bearing: step 8, image 1 of 1
    • Begin with the top of the device facing up.
    Ask FixBot
  9. Ryobi RJ1861V Motor Replacement: step 9, image 1 of 1
    • Insert needle nose pliers to remove the retaining pin at the top of the bearing.
    Ask FixBot
  10. Ryobi RJ1861V Motor Replacement: step 10, image 1 of 1
    • Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
    Ask FixBot
  11. Ryobi RJ1861V Motor Replacement, Motor: step 11, image 1 of 1
    • The motor is divided into two sections, one attached to the gear case and one attached to the handle.
    • This arrow indicates the section attached to the gear case.
    • This arrow indicates the section attached to the handle.
    Ask FixBot
  12. Ryobi RJ1861V Motor Replacement: step 12, image 1 of 3 Ryobi RJ1861V Motor Replacement: step 12, image 2 of 3 Ryobi RJ1861V Motor Replacement: step 12, image 3 of 3
    • Use a Torx T5 screwdriver to remove the four screws attaching the motor to the gear case.
    Ask FixBot
  13. Ryobi RJ1861V Motor Replacement: step 13, image 1 of 1
    • Use a Torx T5 screwdriver to remove the two screws inside the motor housing of the handle.
    Ask FixBot
  14. Ryobi RJ1861V Motor Replacement: step 14, image 1 of 2 Ryobi RJ1861V Motor Replacement: step 14, image 2 of 2
    • Remove the four screws on the back of the housing with a Torx T5 screwdriver.
    • Flip the housing over and pull the motor up and out of the housing.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 31
All Time: 718
