Ryobi P516 Top Case Replacement
    1. Ryobi P516 Top Case Replacement, Top Case: step 1, image 1 of 2 Ryobi P516 Top Case Replacement, Top Case: step 1, image 2 of 2
      • Using the 5mm hex key included at the base of the saw, loosen the set screw at the front of the saw.
      • The front guard will now slide out from the front of the saw.
      Ask FixBot
    2. Ryobi P516 Top Case Replacement: step 2, image 1 of 3 Ryobi P516 Top Case Replacement: step 2, image 2 of 3 Ryobi P516 Top Case Replacement: step 2, image 3 of 3
      • Remove the two 10mm T20 Torx screws from the front of the saw.
      • Pull out the front plate.
      Ask FixBot
    3. Ryobi P516 Top Case Replacement: step 3, image 1 of 3 Ryobi P516 Top Case Replacement: step 3, image 2 of 3 Ryobi P516 Top Case Replacement: step 3, image 3 of 3
      • Start at the middle of the device and begin to pry up the rubber grip.
      • Pull the rubber portion inside out towards the front of the saw.
      Ask FixBot
    4. Ryobi P516 Top Case Replacement: step 4, image 1 of 1
      • Remove all twelve 14mm T20 Torx screws from the main case of the device.
      Ask FixBot
    5. Ryobi P516 Top Case Replacement: step 5, image 1 of 3 Ryobi P516 Top Case Replacement: step 5, image 2 of 3 Ryobi P516 Top Case Replacement: step 5, image 3 of 3
      • Remove the four 35mm Phillips #2 screws.
      • Pry the two case halves apart starting at the middle of the saw.
      • Watch out for any loose parts from inside the saw that may fall out during this step.
      Ask FixBot
    6. Ryobi P516 Top Case Replacement: step 6, image 1 of 1
      • Continue splitting the case until the top piece of the case is free and set it aside.
      Ask FixBot
6 other people completed this guide.
2 Guide Comments
P516 blade locking parts
Bill clark - Reply Share
P516 blade locking parts breakdown, please ?
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 51
All Time: 5,541
