Up to 20% off select tools
Ryobi P501G Shell Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
63
All Time:
888
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the shell of your Ryobi P501G is damaged or compromised, you might want to think about replacing it. A damaged shell might be the result of wear and tear, or overuse. The opening up is not too complex and does not require a lot of experience. You will need the indicated screwdrivers to accomplish the task. There are no warnings or potential hazards when replacing this part.
    1. Ryobi P501G Shell Replacement, Blade: step 1, image 1 of 1
      • Locate the area where the blade is connected to the motor, where the circular covering is on the Ryobi P501G.
      Ask FixBot
    2. Ryobi P501G Shell Replacement: step 2, image 1 of 2 Ryobi P501G Shell Replacement: step 2, image 2 of 2
      • Unscrew clockwise and remove the bearing in the middle, connecting the blade to the motor. This will also allow removal of the blade guard.
      Ask FixBot
    3. Ryobi P501G Shell Replacement: step 3, image 1 of 3 Ryobi P501G Shell Replacement: step 3, image 2 of 3 Ryobi P501G Shell Replacement: step 3, image 3 of 3
      • Remove the four black screws holding the black bearing and remove the bearing itself.
      Ask FixBot
    4. Ryobi P501G Shell Replacement: step 4, image 1 of 1
      • Once the black bearing is off, remove the transparent cover of the blade.
      • Once the cover is off, remove the blade.
      • Place the new blade with the flat notches lined up with the flat notches on the motor axle.
      Ask FixBot
    1. Ryobi P501G Shell Replacement, Shell: step 5, image 1 of 3 Ryobi P501G Shell Replacement, Shell: step 5, image 2 of 3 Ryobi P501G Shell Replacement, Shell: step 5, image 3 of 3
      • Remove the three screws on the inside base of the metal casing of the blade.
      • Pull the metal blade casing off of the Ryobi P501G body.
      Ask FixBot
    2. Ryobi P501G Shell Replacement: step 6, image 1 of 3 Ryobi P501G Shell Replacement: step 6, image 2 of 3 Ryobi P501G Shell Replacement: step 6, image 3 of 3
      • Remove all of the screws located on the right side of the saw.
      • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
      • Pull back the shell to access the housed parts underneath.
      Ask FixBot
Author
with
Eeshan Mishra
424 Reputation
4 Guides authored
Cal Poly, Team S1-G2, Maness Spring 2019 Member of Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 63
All Time: 888
