Ryobi P501G Motor Replacement
    1. Ryobi P501G Motor Replacement, Motor: step 1, image 1 of 1
      • Locate the screws at the top face of the saw, on the green plastic surface covering.
      Ask FixBot
    2. Ryobi P501G Motor Replacement: step 2, image 1 of 2 Ryobi P501G Motor Replacement: step 2, image 2 of 2
      • Locate the eight outer screws of the plastic green encasement. They are marked in red in the picture.
      • Using a T15 torx screwdriver, unscrew all the holes, taking care not to lose any!
      Ask FixBot
    3. Ryobi P501G Motor Replacement: step 3, image 1 of 2 Ryobi P501G Motor Replacement: step 3, image 2 of 2
      • Open up the top side of the encasement to reveal the internal parts of the saw.
      • Locate the motor.
      Ask FixBot
    4. Ryobi P501G Motor Replacement: step 4, image 1 of 2 Ryobi P501G Motor Replacement: step 4, image 2 of 2
      • Using the T15 torx screwdriver, unscrew all four of the screws to free the motor from the encasement.
      Ask FixBot
    5. Ryobi P501G Motor Replacement: step 5, image 1 of 1
      • Remove the motor and replace with a new one if needed.
      • Be careful when handling the motor- it may be very dirty/greasy. You might want to wear gloves for this step!
      Ask FixBot
Sophia Arias
255 Reputation
2 Guides authored
Cal Poly, Team S1-G2, Maness Spring 2019 Member of Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 Members
72 Guides authored
1 Guide Comment
Where can I find Ryobi circular saw motor Part #206216001? Thanks.
De-Hong Tang - Reply Share
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 47
All Time: 2,764
