Ryobi P501G Blade Replacement
    1. Ryobi P501G Blade Replacement, Blade: step 1, image 1 of 1
      • Locate the area where the blade is connected to the motor, where the circular covering is on the Ryobi P501G.
      Ask FixBot
    2. Ryobi P501G Blade Replacement: step 2, image 1 of 2 Ryobi P501G Blade Replacement: step 2, image 2 of 2
      • Unscrew clockwise and remove the bearing in the middle, connecting the blade to the motor. This will also allow removal of the blade guard.
      Ask FixBot
    3. Ryobi P501G Blade Replacement: step 3, image 1 of 3 Ryobi P501G Blade Replacement: step 3, image 2 of 3 Ryobi P501G Blade Replacement: step 3, image 3 of 3
      • Remove the four black screws holding the black bearing and remove the bearing itself.
      Ask FixBot
    4. Ryobi P501G Blade Replacement: step 4, image 1 of 1
      • Once the black bearing is off, remove the transparent cover of the blade.
      • Once the cover is off, remove the blade.
      • Place the new blade with the flat notches lined up with the flat notches on the motor axle.
      Ask FixBot
Eeshan Mishra
424 Reputation
4 Guides authored
Cal Poly, Team S1-G2, Maness Spring 2019 Member of Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 25
All Time: 1,561
