Up to 20% off select tools
Ryobi P411 Motor Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
65
All Time:
528
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 35 - 45 minutes
Difficulty: Difficult
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a defective motor in your Ryobi P411. The motor is the part that is inside the sander that activates the machine when the switch trigger and switch are depressed. If your device is not turning on, the cause might be a defective motor. Before replacing the motor, make sure to review the troubleshooting page to make sure nothing else is preventing your Ryobi P411 from turning on. Make sure to remove the battery before beginning.
Replacing the motor requires desoldering and resoldering a couple of connections. Review the How to Solder and Desolder Connections guide before beginning if you're unfamiliar with soldering.
    1. Ryobi P411 Motor Replacement, Pad Assembly: step 1, image 1 of 3 Ryobi P411 Motor Replacement, Pad Assembly: step 1, image 2 of 3 Ryobi P411 Motor Replacement, Pad Assembly: step 1, image 3 of 3
      • Remove the sanding pad to expose the screws at the bottom of the sander.
      Ask FixBot
    2. Ryobi P411 Motor Replacement: step 2, image 1 of 3 Ryobi P411 Motor Replacement: step 2, image 2 of 3 Ryobi P411 Motor Replacement: step 2, image 3 of 3
      • Remove the four M5 x 8.9mm screws with a T6 Torx screwdriver.
      • Remove the pad assembly.
      Ask FixBot
    1. Ryobi P411 Motor Replacement, Switch Trigger: step 3, image 1 of 3 Ryobi P411 Motor Replacement, Switch Trigger: step 3, image 2 of 3 Ryobi P411 Motor Replacement, Switch Trigger: step 3, image 3 of 3
      • Push the switch trigger gently from the back to pull it out from the open face of the sander.
      Ask FixBot
    1. Ryobi P411 Motor Replacement, Switch: step 4, image 1 of 3 Ryobi P411 Motor Replacement, Switch: step 4, image 2 of 3 Ryobi P411 Motor Replacement, Switch: step 4, image 3 of 3
      • Remove the switch from its housing.
      • Take care not to strain the connected cables.
      Ask FixBot
    2. Ryobi P411 Motor Replacement: step 5, image 1 of 3 Ryobi P411 Motor Replacement: step 5, image 2 of 3 Ryobi P411 Motor Replacement: step 5, image 3 of 3
      • Use a soldering iron to desolder the two switch connections.
      • If you're unfamiliar with soldering, review this guide.
      Ask FixBot
    1. Ryobi P411 Motor Replacement, Fan and Bearing Cap: step 6, image 1 of 3 Ryobi P411 Motor Replacement, Fan and Bearing Cap: step 6, image 2 of 3 Ryobi P411 Motor Replacement, Fan and Bearing Cap: step 6, image 3 of 3
      • Remove the rubber brake from the bottom of the sander.
      Ask FixBot
    2. Ryobi P411 Motor Replacement: step 7, image 1 of 3 Ryobi P411 Motor Replacement: step 7, image 2 of 3 Ryobi P411 Motor Replacement: step 7, image 3 of 3
      • Use a T20 Torx screwdriver to loosen the 15.8 mm screw at the bottom of the sander.
      • Remove the screw and washer.
      Ask FixBot
    3. Ryobi P411 Motor Replacement: step 8, image 1 of 3 Ryobi P411 Motor Replacement: step 8, image 2 of 3 Ryobi P411 Motor Replacement: step 8, image 3 of 3
      • Remove the fan and bearing cap.
      Ask FixBot
    1. Ryobi P411 Motor Replacement, Motor: step 9, image 1 of 3 Ryobi P411 Motor Replacement, Motor: step 9, image 2 of 3 Ryobi P411 Motor Replacement, Motor: step 9, image 3 of 3
      • Desolder the motor connections from the switch and power supply.
      • Remove the motor from its housing.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Paula Meier
769 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 65
All Time: 528
