Ryobi P411 Fan and Bearing Cap Replacement
  1. Ryobi P411 Fan and Bearing Cap Replacement, Pad Assembly: step 1, image 1 of 3 Ryobi P411 Fan and Bearing Cap Replacement, Pad Assembly: step 1, image 2 of 3 Ryobi P411 Fan and Bearing Cap Replacement, Pad Assembly: step 1, image 3 of 3
    • Remove the sanding pad to expose the screws at the bottom of the sander.
    Ask FixBot
  2. Ryobi P411 Fan and Bearing Cap Replacement: step 2, image 1 of 3 Ryobi P411 Fan and Bearing Cap Replacement: step 2, image 2 of 3 Ryobi P411 Fan and Bearing Cap Replacement: step 2, image 3 of 3
    • Remove the four M5 x 8.9mm screws with a T6 Torx screwdriver.
    • Remove the pad assembly.
    Ask FixBot
  3. Ryobi P411 Fan and Bearing Cap Replacement, Casing: step 3, image 1 of 2 Ryobi P411 Fan and Bearing Cap Replacement, Casing: step 3, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the eight M4 x 18.5mm screws from the side of the casing.
    Ask FixBot
  4. Ryobi P411 Fan and Bearing Cap Replacement: step 4, image 1 of 3 Ryobi P411 Fan and Bearing Cap Replacement: step 4, image 2 of 3 Ryobi P411 Fan and Bearing Cap Replacement: step 4, image 3 of 3
    • Open the sander by separating each half of the case apart.
    Ask FixBot
  5. Ryobi P411 Fan and Bearing Cap Replacement, Fan and Bearing Cap: step 5, image 1 of 3 Ryobi P411 Fan and Bearing Cap Replacement, Fan and Bearing Cap: step 5, image 2 of 3 Ryobi P411 Fan and Bearing Cap Replacement, Fan and Bearing Cap: step 5, image 3 of 3
    • Remove the rubber brake from the bottom of the sander.
    Ask FixBot
  6. Ryobi P411 Fan and Bearing Cap Replacement: step 6, image 1 of 3 Ryobi P411 Fan and Bearing Cap Replacement: step 6, image 2 of 3 Ryobi P411 Fan and Bearing Cap Replacement: step 6, image 3 of 3
    • Use a T20 Torx screwdriver to loosen the 15.8 mm screw at the bottom of the sander.
    • Remove the screw and washer.
    Ask FixBot
  7. Ryobi P411 Fan and Bearing Cap Replacement: step 7, image 1 of 3 Ryobi P411 Fan and Bearing Cap Replacement: step 7, image 2 of 3 Ryobi P411 Fan and Bearing Cap Replacement: step 7, image 3 of 3
    • Remove the fan and bearing cap.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Paula Meier
769 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 212
