Ryobi P277 Reversing Switch Replacement
    1. Ryobi P277 Reversing Switch Replacement, Reversing Switch: step 1, image 1 of 2 Ryobi P277 Reversing Switch Replacement, Reversing Switch: step 1, image 2 of 2
      • Lay the device on its side with the warning label facing you.
      • Remove the eight 5 mm screws using a TR10 Torx screwdriver.
      • Separate the two halves of the casing by pulling up on the top half.
      • The two halves are still attached, so use caution when opening the device.
      Ask FixBot
    2. Ryobi P277 Reversing Switch Replacement: step 2, image 1 of 1
      • The reversing switch lies between the trigger and the motor.
      • Carefully remove the reversing switch from the device.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 43
All Time: 496
