Up to 20% off select tools
Ryobi P271 Trigger Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
68
All Time:
1,155
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This repair is for if your trigger on your drill stops working or has issues cutting in and out. Soldering is required for this repair and it will fix your drill trigger for future use.
    1. Ryobi P271 Trigger Replacement, Battery: step 1, image 1 of 3 Ryobi P271 Trigger Replacement, Battery: step 1, image 2 of 3 Ryobi P271 Trigger Replacement, Battery: step 1, image 3 of 3
      • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
      Ask FixBot
    1. Ryobi P271 Trigger Replacement, Trigger: step 2, image 1 of 1
      • Remove the screws from the drill's casing to gain access to the interior.
      Ask FixBot
    2. Ryobi P271 Trigger Replacement: step 3, image 1 of 1
      • Lift and remove the casing off of the drill body.
      Ask FixBot
    3. Ryobi P271 Trigger Replacement: step 4, image 1 of 1
      • Carefully lift and remove the battery clip, trigger, motor, and everything connected to the wires and pull straight out of the drill.
      Ask FixBot
    4. Ryobi P271 Trigger Replacement: step 5, image 1 of 1
      • Separate the wiring from the trigger and the motor using a soldering iron and them replace them with a new trigger and motor by soldering the wires back together.
      • Follow this guide for soldering tips.
      Ask FixBot
Author
with
nathan krehbiel
229 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 68
All Time: 1,155
