Ryobi P271 Reverse Switch Replacement
    1. Ryobi P271 Reverse Switch Replacement, Battery: step 1, image 1 of 3 Ryobi P271 Reverse Switch Replacement, Battery: step 1, image 2 of 3 Ryobi P271 Reverse Switch Replacement, Battery: step 1, image 3 of 3
      • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
      Ask FixBot
    1. Ryobi P271 Reverse Switch Replacement, Reverse Switch: step 2, image 1 of 1
      • Remove all ten Torx screws from the drill's case.
      Ask FixBot
    2. Ryobi P271 Reverse Switch Replacement: step 3, image 1 of 1
      • Gently pull the casing apart.
      • Separating the casing too quickly could cause internals to become loose, and not easily seat together upon reassembly.
      Ask FixBot
    3. Ryobi P271 Reverse Switch Replacement: step 4, image 1 of 1
      • Remove the trigger so that it can fully expose the reverse switch.
      Ask FixBot
    4. Ryobi P271 Reverse Switch Replacement: step 5, image 1 of 1
      • Firmly grab the reverse switch and pull on it until it comes out of its socket.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
nathan krehbiel
229 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 1,894
