Ryobi P235 Magnetic Tray Replacement
    1. Ryobi P235 Magnetic Tray Replacement, Battery: step 1, image 1 of 2 Ryobi P235 Magnetic Tray Replacement, Battery: step 1, image 2 of 2
      • Push in both push tabs on the battery at the same time.
      • They are located below the green housing and are in the middle on both sides of the battery.
      Ask FixBot
    2. Ryobi P235 Magnetic Tray Replacement: step 2, image 1 of 2 Ryobi P235 Magnetic Tray Replacement: step 2, image 2 of 2
      • Pull the battery away from the drill housing while holding in both tabs.
      Ask FixBot
    1. Ryobi P235 Magnetic Tray Replacement, Magnetic Tray: step 3, image 1 of 2 Ryobi P235 Magnetic Tray Replacement, Magnetic Tray: step 3, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
      Ask FixBot
    2. Ryobi P235 Magnetic Tray Replacement: step 4, image 1 of 2 Ryobi P235 Magnetic Tray Replacement: step 4, image 2 of 2
      • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
      Ask FixBot
    3. Ryobi P235 Magnetic Tray Replacement: step 5, image 1 of 2 Ryobi P235 Magnetic Tray Replacement: step 5, image 2 of 2
      • Open the housing with the data label facing up.
      Ask FixBot
    4. Ryobi P235 Magnetic Tray Replacement: step 6, image 1 of 1
      • Remove the magnetic tray from the device.
      Ask FixBot
Paul Sousa
817 Reputation
5 Guides authored
1 Guide Comment
Thanks for sharing, I was actually looking for these steps.
Mark Robert - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 16
All Time: 629
