Ryobi P235 Bit-Holder Replacement
    1. Ryobi P235 Bit-Holder Replacement, Battery: step 1, image 1 of 2 Ryobi P235 Bit-Holder Replacement, Battery: step 1, image 2 of 2
      • Push in both push tabs on the battery at the same time.
      • They are located below the green housing and are in the middle on both sides of the battery.
      Ask FixBot
    2. Ryobi P235 Bit-Holder Replacement: step 2, image 1 of 2 Ryobi P235 Bit-Holder Replacement: step 2, image 2 of 2
      • Pull the battery away from the drill housing while holding in both tabs.
      Ask FixBot
    1. Ryobi P235 Bit-Holder Replacement, Bit-Holder: step 3, image 1 of 2 Ryobi P235 Bit-Holder Replacement, Bit-Holder: step 3, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
      Ask FixBot
    2. Ryobi P235 Bit-Holder Replacement: step 4, image 1 of 2 Ryobi P235 Bit-Holder Replacement: step 4, image 2 of 2
      • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
      Ask FixBot
    3. Ryobi P235 Bit-Holder Replacement: step 5, image 1 of 2 Ryobi P235 Bit-Holder Replacement: step 5, image 2 of 2
      • Open the housing with the data label facing up.
      Ask FixBot
    4. Ryobi P235 Bit-Holder Replacement: step 6, image 1 of 2 Ryobi P235 Bit-Holder Replacement: step 6, image 2 of 2
      • Remove the old bit holder.
      Ask FixBot
Paul Sousa
817 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 33
All Time: 1,272
