Up to 20% off select tools
Ryobi P235 Battery Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
72
All Time:
1,386
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will show how to replace the standardized battery of this power tool, no extra tools or equipment necessary, in less than a minute.
The Ryobi P235 is a impact driver which makes it a more powerful and compact than a power drill but the cons are that it is more complex to change the drill.
Warning the 18V battery may expand slightly do not be alarmed, but be prepared by having a metal bucket of sand or sawdust to put the swollen battery into.
The link here is for battery safety: What to do with a swollen battery
    1. Ryobi P235 Battery Replacement, Battery: step 1, image 1 of 2 Ryobi P235 Battery Replacement, Battery: step 1, image 2 of 2
      • Push in both push tabs on the battery at the same time.
      • They are located below the green housing and are in the middle on both sides of the battery.
      Ask FixBot
    2. Ryobi P235 Battery Replacement: step 2, image 1 of 2 Ryobi P235 Battery Replacement: step 2, image 2 of 2
      • Pull the battery away from the drill housing while holding in both tabs.
      Ask FixBot
3 other people completed this guide.
Author
with
Paul Sousa
817 Reputation
5 Guides authored
1 Guide Comment
Replacement Power Tool Battery for Ryobi P235
Type: Li-ion
Volt: 18V
Capacity: 2500mAh
Color: Black
Weight: 210g
Dimension: 135.70 x 76.00 x 98.30mm
View more about this battery on http://www.drillbattery.co.uk/batterysal...
Drillbatterycomau - Reply Share
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 72
All Time: 1,386
