Ryobi P202 Battery Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
112
All Time:
3,593
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide is about removing the battery from the drill body in order to replace or charge it.
    1. Ryobi P202 Battery Replacement, Battery: step 1, image 1 of 3 Ryobi P202 Battery Replacement, Battery: step 1, image 2 of 3 Ryobi P202 Battery Replacement, Battery: step 1, image 3 of 3
      • The battery can shock you. Only touch plastic, non-conductive components.
      • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
      Ask FixBot
Joseph Eckstein
1,596 Reputation
9 Guides authored
Cal Poly, Team 17-6, Forte Spring 2015 Member of Cal Poly, Team 17-6, Forte Spring 2015
CPSU-FORTE-S15S17G6
4 Members
108 Guides authored
1 Guide Comment
Replacement Cordless Drill Battery for Ryobi P202
Type: Li-ion
Volt: 18V
Capacity: 2500mAh
Color: Black
Weight: 210g
Dimension: 135.70 x 76.00 x 98.30mm
Go to view more about this battery on http://www.drill-batteries.co.uk/shopbat...
Drillbatterycomau - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 112
All Time: 3,593
