Ryobi D620H Power Cord Replacement
    1. Ryobi D620H Power Cord Replacement, Right Side Case Removal: step 1, image 1 of 1
      • Turn the drill so that the screws face upwards.
      • Use the Torx T20 screwdriver to remove all nine screws.
      Ask FixBot
    2. Ryobi D620H Power Cord Replacement: step 2, image 1 of 2 Ryobi D620H Power Cord Replacement: step 2, image 2 of 2
      • Insert the end of an opening tool between the right and left sides of the drill to pry the right side of the case.
      • Remove the right side case to expose the inside of the drill.
      Ask FixBot
    1. Ryobi D620H Power Cord Replacement, Power Cord: step 3, image 1 of 1
      • The bend relief cover at the bottom of the handle.
      • Follow the wires coming out of the bend relief cover to the white power cord clamp with the two 14 mm black PH1 screws.
      Ask FixBot
    2. Ryobi D620H Power Cord Replacement: step 4, image 1 of 2 Ryobi D620H Power Cord Replacement: step 4, image 2 of 2
      • Unscrew the two 14 mm PH1 screws holding the power cord wire in place.
      • Lift the switch box from its place gently.
      Ask FixBot
    3. Ryobi D620H Power Cord Replacement: step 5, image 1 of 3 Ryobi D620H Power Cord Replacement: step 5, image 2 of 3 Ryobi D620H Power Cord Replacement: step 5, image 3 of 3
      • Remove the two little screws holding the brass terminal lugs in place. Although it is not required, you can remove the screws completely if you find that doing so is more convenient.
      • Gently pull the white positive and black negative wires that are connected to the switch box.
      • Slide the bend relief guard off the cord towards the loose connections.
      Ask FixBot
Slide the bend relief cover on the new power cord and reattach all of the electrical connections in reverse order.
Congratulations you've successfully replaced the power cord on your hammer drill!
Jacob da Ponte
469 Reputation
5 Guides authored
UMass Dartmouth, Team 1-2, Petersen Fall 2023 Member of UMass Dartmouth, Team 1-2, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 22
All Time: 385
