Up to 20% off select tools
Ryobi D620H Chuck Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
130
All Time:
953
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Student In Progress
This guide is being worked on by hardworking students.
Parts
Tools
Introduction
Go to step 1 ↓
Over time, your chuck may get damaged and stop working like it should. You can replace the chuck and prolong the life of your Ryobi D620H hammer drill by following the steps below.
Before you start:
You'll need:
one Phillips #3 screwdriver
one 1/4" or larger hex Allen wrench
one rubber mallet
one replacement chuck
Safety:
Make sure that your Ryobi is unplugged before you perform any repairs.
    1. Ryobi D620H Chuck Replacement, Chuck: step 1, image 1 of 1
      • Use the chuck key to open the jaws of the chuck all the way.
      Ask FixBot
    2. Ryobi D620H Chuck Replacement: step 2, image 1 of 1
      • IMPORTANT: the screw inside of the chuck is a left-handed screw, so you will have to turn it to the right, or clockwise, to loosen it.
      • Use your #3 Phillips screwdriver to remove the screw inside the chuck.
      Ask FixBot
      • Insert the 1/4' hex Allen wrench into the chuck and tighten the jaws around it.
      Ask FixBot
      • Use the Allen wrench to turn the chuck counterclockwise, or to the left, to loosen and remove the chuck.
      • You may need to tap the Allen wrench with a rubber mallet to help loosen the chuck.
      Ask FixBot
      • Attach your new chuck by turning it clockwise, or to the right, to tighten it onto the drill.
      Ask FixBot
      • Insert the screw into the bottom of the chuck.
      • Use the #3 Phillips screwdriver to turn it counterclockwise, or the left, to tighten it.
      Ask FixBot
Author
with
Jacob da Ponte
469 Reputation
5 Guides authored
UMass Dartmouth, Team 1-2, Petersen Fall 2023 Member of UMass Dartmouth, Team 1-2, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 130
All Time: 953
