Ryobi CSB135L Power Cord Replacement
    1. Ryobi CSB135L Power Cord Replacement, Power Cord: step 1, image 1 of 1
      • Place the saw on a flat surface.
      • Make sure the saw is unplugged and unpowered.
      Ask FixBot
    2. Ryobi CSB135L Power Cord Replacement: step 2, image 1 of 2 Ryobi CSB135L Power Cord Replacement: step 2, image 2 of 2
      • Remove the six M4x16mm Phillips screws and the two M4.5x35mm screws using a Phillips #2 screwdriver.
      • Remove the front facing half of the handle assembly exposing the internals of the saw.
      Ask FixBot
    3. Ryobi CSB135L Power Cord Replacement: step 3, image 1 of 2 Ryobi CSB135L Power Cord Replacement: step 3, image 2 of 2
      • After removing the handle assembly locate the trigger switch and wire nut in the saw.
      • Remove the screw from the black wire of the power cord using a Phillips screwdriver. Then remove the wire.
      • Loosen the wire nut and remove the neutral wire from the power cord.
      Ask FixBot
    4. Ryobi CSB135L Power Cord Replacement: step 4, image 1 of 1
      • Remove the power cord from the saw.
      • To insert the replacement power cord, insert the black wire of the cord into the trigger switch and tighten the screw. Take the neutral/white wire of the new cord and insert it into the wire nut and tighten the nut.
      • Wire strippers may be needed when installing the new power cord to expose the copper wire.
      Ask FixBot
Nathanael Winchell
689 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 575
