Ryobi CSB135L Motor Housing Replacement
  1. Ryobi CSB135L Motor Housing Replacement, Motor Housing: step 1, image 1 of 1
    • Remove the three M4.5 x 35mm screws that hold the motor housing to the blade housing using a Phillips screwdriver.
    • Although not required for motor housing removal, the two M4 x 16 mm Phillips head screws must be removed for access to the top of the motor.
    Ask FixBot
  2. Ryobi CSB135L Motor Housing Replacement: step 2, image 1 of 1
    • Remove the three M3.5 x 16 mm screws that hold on the laser cover using a Phillips screwdriver.
    • The wires that power the laser prevent the motor housing from coming off, so the laser must be removed.
    Ask FixBot
  3. Ryobi CSB135L Motor Housing Replacement: step 3, image 1 of 1
    • Pry the motor housing (green plastic) from the blade housing (gray plastic) using a metal spudger or any small pry bar.
    Ask FixBot
  4. Ryobi CSB135L Motor Housing Replacement: step 4, image 1 of 1
    • Fully remove the motor housing and blade cover to expose the motor and laser.
    Ask FixBot
Nathanael Winchell
689 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 40
All Time: 290
