Up to 20% off select tools
Ryobi CSB135L Laser Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
71
All Time:
827
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 35 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
This guide will show you how to properly replace the guiding laser in the Ryobi CSB135L. If the symptoms in our troubleshooting page for a malfunctioning laser align with the symptoms your Ryobi CSB135L are experiencing your laser is most likely damaged.
    1. Ryobi CSB135L Laser Replacement, Motor Housing: step 1, image 1 of 1
      • Remove the three M4.5 x 35mm screws that hold the motor housing to the blade housing using a Phillips screwdriver.
      • Although not required for motor housing removal, the two M4 x 16 mm Phillips head screws must be removed for access to the top of the motor.
      Ask FixBot
    2. Ryobi CSB135L Laser Replacement: step 2, image 1 of 1
      • Remove the three M3.5 x 16 mm screws that hold on the laser cover using a Phillips screwdriver.
      • The wires that power the laser prevent the motor housing from coming off, so the laser must be removed.
      Ask FixBot
    3. Ryobi CSB135L Laser Replacement: step 3, image 1 of 1
      • Pry the motor housing (green plastic) from the blade housing (gray plastic) using a metal spudger or any small pry bar.
      Ask FixBot
    4. Ryobi CSB135L Laser Replacement: step 4, image 1 of 1
      • Fully remove the motor housing and blade cover to expose the motor and laser.
      Ask FixBot
    1. Ryobi CSB135L Laser Replacement, Laser: step 5, image 1 of 1
      • Regardless of the assembly state of the saw, remove the M4 x 16 mm screws that hold the two pieces of the handle together using a Phillips screwdriver.
      Ask FixBot
    2. Ryobi CSB135L Laser Replacement: step 6, image 1 of 1
      • Unplug the laser from the handle.
      Ask FixBot
    3. Ryobi CSB135L Laser Replacement: step 7, image 1 of 1
      • Remove the laser that is woven through the plastic of the saw's handle.
      Ask FixBot
Author
with
Nathanael Winchell
689 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 71
All Time: 827
