Up to 20% off select tools
Ryobi CSB125 Trigger Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
71
All Time:
1,144
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to properly install a new trigger to your Ryobi CSB125 circular saw. If the trigger is no longer working or frequently becomes jammed, then you should highly consider replacing it. This troubleshooting page will help diagnose any potential problems occurring due to a faulty trigger switch. In the event that a new trigger is needed, this guide will show the steps to properly install a new one. The only tools you will need are a #2 Phillips screwdriver and a pair of wire strippers. This guide will cover how to access the internal wires that connect to the trigger switch.
    1. Ryobi CSB125 Trigger Replacement, Trigger: step 1, image 1 of 1
      • Place the saw down on a flat surface with the motor facing up.
      • Make sure that the saw is unplugged from any power source.
      Ask FixBot
    2. Ryobi CSB125 Trigger Replacement: step 2, image 1 of 2 Ryobi CSB125 Trigger Replacement: step 2, image 2 of 2
      • Use the Phillips #2 screwdriver to remove the five M4x16mm screws.
      Ask FixBot
    3. Ryobi CSB125 Trigger Replacement: step 3, image 1 of 1
      • Use the Phillips #2 screwdriver to remove the two M45x35mm screws.
      Ask FixBot
    4. Ryobi CSB125 Trigger Replacement: step 4, image 1 of 1
      • Disconnect the two black wires by unscrewing them from the trigger switch using the Phillips #2 screwdriver.
      Ask FixBot
    5. Ryobi CSB125 Trigger Replacement: step 5, image 1 of 1
      • Remove the trigger from the saw.
      • You may have to use the wire strippers to the copper on the new plug.
      • It is important that the wires are properly run in their tracks. Failure to do so could result in pinching a wire, which could damage the plug.
      Ask FixBot
3 other people completed this guide.
Author
with
Curtis Melo
1,093 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 71
All Time: 1,144
