Up to 20% off select tools
Ryobi CSB125 Protective Shell Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
74
All Time:
3,081
Comments: 5
1 comment on steps, 4 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to properly install a new protective shell to your Ryobi CSB125 circular saw. If the protective shield is cracked/damaged, or isn’t functioning properly, then the protective shell should be replaced. This troubleshooting pagewill help diagnose any potential problems occurring due to a faulty protective shell. In the event that a new shell is needed, this guide will show the steps to properly install a new one. The only tools you will need are a 7”/32 Allen key and T20 Torx screwdriver.
    1. Ryobi CSB125 Protective Shell Replacement, Protective Shell: step 1, image 1 of 1
      • Place the saw on a flat surface with the blade facing up.
      • Make sure that the saw is unplugged from any power source.
      Ask FixBot
    2. Ryobi CSB125 Protective Shell Replacement: step 2, image 1 of 1
      • Remove the bumper by using the T20 Torx screwdriver to loosen the M5 x 20mm screw.
      Ask FixBot
    3. Ryobi CSB125 Protective Shell Replacement: step 3, image 1 of 2 Ryobi CSB125 Protective Shell Replacement: step 3, image 2 of 2
      • Use the 7”/32 allen key to loosen the 5/16-18 x 9/16 in. blade screw.
      Ask FixBot
    4. Ryobi CSB125 Protective Shell Replacement: step 4, image 1 of 1
      • Remove the 5/16-18 x 9/16 in. blade screw, spring washer, the outer blade washer, the blade, and the inner blade washer.
      Ask FixBot
    5. Ryobi CSB125 Protective Shell Replacement: step 5, image 1 of 3 Ryobi CSB125 Protective Shell Replacement: step 5, image 2 of 3 Ryobi CSB125 Protective Shell Replacement: step 5, image 3 of 3
      • Use the Phillips #2 screwdriver to remove the four M4x16mm screws shown.
      • You will need to rotate the protective shell around in order to access them.
      Ask FixBot
    6. Ryobi CSB125 Protective Shell Replacement: step 6, image 1 of 1
      • Remove the lower blade guard support assembly from the rest of the saw.
      • Remove the protective shell.
      Ask FixBot
4 other people completed this guide.
Author
with
Curtis Melo
1,093 Reputation
5 Guides authored
4 Guide Comments
Instructions fail at step #5. Bottom-left screw is under the plastic blade guard which blocks removal of the screw. Blade guard covers the screw no matter how it’s positioned.
Michael Bluejay - Reply Share
If you wiggle the plastic you can remove
I was able to remove… be patient it does work
Adrian Isbister - Reply Share
Instructions also fail at step #6. I have no idea how to remove the plastic blade guard from the axle so I can transfer it to the new (replacement) blade guard.
I also was struggling… … but if you look closely there is a thin metal ring around the center plastic ring that the spindle runs through… this has a split in it…. I used a small flat Precision screwdriver (type used to tighten reading glasses,etc)and was able to pry at the split and remove the thin metal ring.
Once removed this frees the plastic guard and it drops right out.
Just reverse to reassemble.
This works… just be patient
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 74
All Time: 3,081
