Ryobi CSB125 Power Cord Replacement
    1. Ryobi CSB125 Power Cord Replacement, Power Cord: step 1, image 1 of 1
      • Place the saw down on a flat surface with the motor facing up.
      • Make sure that the saw is unplugged from any power source.
      Ask FixBot
    2. Ryobi CSB125 Power Cord Replacement: step 2, image 1 of 2 Ryobi CSB125 Power Cord Replacement: step 2, image 2 of 2
      • Use the Phillips #2 screwdriver to remove the five M4x16mm screws.
      Ask FixBot
    3. Ryobi CSB125 Power Cord Replacement: step 3, image 1 of 1
      • Use the Phillips #2 screwdriver to remove the two M45x35mm screws.
      Ask FixBot
    4. Ryobi CSB125 Power Cord Replacement: step 4, image 1 of 2 Ryobi CSB125 Power Cord Replacement: step 4, image 2 of 2
      • To remove the plug from the saw you will need to disconnect the two wires that come from the plug.
      • Remove the black wire by unscrewing it from the trigger switch using the Phillips #2 screwdriver.
      • Remove the white wire by twisting off the plastic wire nut to separate the two white wires.
      Ask FixBot
    5. Ryobi CSB125 Power Cord Replacement: step 5, image 1 of 1
      • Remove the plug from the saw.
      • You may have to use the wire strippers to expose the copper on the new plug.
      • It is important that the wires are properly run in their tracks. Failure to do so could result in pinching a wire, which could damage the plug.
      Ask FixBot
5 other people completed this guide.
Curtis Melo
1,093 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 38
All Time: 2,290
