Up to 20% off select tools
Rowenta Focus Material Setting Knob Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
118
All Time:
2,784
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The material setting knob on the Rowenta Focus DW5080 controls the amount of steam and heat used based on the specific material being ironed. If this button becomes stuck or is not changing the steam amount, the knob needs to be replaced following this replacement guide.
Prior to beginning this repair, the iron must be off and cooled down to avoid burns.
    1. Rowenta Focus Material Setting Knob Replacement, Power Assembly: step 1, image 1 of 2 Rowenta Focus Material Setting Knob Replacement, Power Assembly: step 1, image 2 of 2
      • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
      • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
      Ask FixBot
    2. Rowenta Focus Material Setting Knob Replacement: step 2, image 1 of 3 Rowenta Focus Material Setting Knob Replacement: step 2, image 2 of 3 Rowenta Focus Material Setting Knob Replacement: step 2, image 3 of 3
      • Pry the back cover of the iron off using a metal spudger.
      • Remove the back cover, exposing the wiring in the iron.
      Ask FixBot
    3. Rowenta Focus Material Setting Knob Replacement: step 3, image 1 of 2 Rowenta Focus Material Setting Knob Replacement: step 3, image 2 of 2
      • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
      • Leave the other cords attached to the main cord.
      Ask FixBot
    4. Rowenta Focus Material Setting Knob Replacement: step 4, image 1 of 2 Rowenta Focus Material Setting Knob Replacement: step 4, image 2 of 2
      • Pull out the motherboard inside handle of iron.
      • Keep it attached to main power cord and other components.
      Ask FixBot
    5. Rowenta Focus Material Setting Knob Replacement: step 5, image 1 of 3 Rowenta Focus Material Setting Knob Replacement: step 5, image 2 of 3 Rowenta Focus Material Setting Knob Replacement: step 5, image 3 of 3
      • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
      Ask FixBot
    1. Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: step 6, image 1 of 3 Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: step 6, image 2 of 3 Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: step 6, image 3 of 3
      • Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
      • Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
      • Lift out the piece.
      Ask FixBot
    2. Rowenta Focus Material Setting Knob Replacement: step 7, image 1 of 3 Rowenta Focus Material Setting Knob Replacement: step 7, image 2 of 3 Rowenta Focus Material Setting Knob Replacement: step 7, image 3 of 3
      • Replace with an identical part by inserting it into the space.
      Ask FixBot
    1. Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: step 8, image 1 of 2 Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: step 8, image 2 of 2
      • Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
      Ask FixBot
    2. Rowenta Focus Material Setting Knob Replacement: step 9, image 1 of 2 Rowenta Focus Material Setting Knob Replacement: step 9, image 2 of 2
      • Unhook the clips on the top of the metal piece.
      • Using the metal spudger, remove the metal piece on the tip of the iron.
      Ask FixBot
    3. Rowenta Focus Material Setting Knob Replacement: step 10, image 1 of 2 Rowenta Focus Material Setting Knob Replacement: step 10, image 2 of 2
      • Using the T20 screwdriver, remove the 20 mm screw that was under the metal piece on the tip of the iron.
      Ask FixBot
    4. Rowenta Focus Material Setting Knob Replacement: step 11, image 1 of 3 Rowenta Focus Material Setting Knob Replacement: step 11, image 2 of 3 Rowenta Focus Material Setting Knob Replacement: step 11, image 3 of 3
      • Using the T20 screwdriver, remove the two 20 mm screws on either side of the back of the iron.
      Ask FixBot
    5. Rowenta Focus Material Setting Knob Replacement: step 12, image 1 of 3 Rowenta Focus Material Setting Knob Replacement: step 12, image 2 of 3 Rowenta Focus Material Setting Knob Replacement: step 12, image 3 of 3
      • Lift the iron up using the handle to completely detach the soleplate.
      Ask FixBot
    1. Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: step 13, image 1 of 3 Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: step 13, image 2 of 3 Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: step 13, image 3 of 3
      • Using the T20 screwdriver, remove both of the 20mm screws on the underside of the iron.
      Ask FixBot
    2. Rowenta Focus Material Setting Knob Replacement: step 14, image 1 of 2 Rowenta Focus Material Setting Knob Replacement: step 14, image 2 of 2
      • Turn the iron over and pull the knob off.
      • Be careful not to tip the iron after removing the knob; there are small springs in the white piece underneath the knob.
      Ask FixBot
Author
with
Bella Navarro
474 Reputation
3 Guides authored
1 Guide Comment
Nice pics, came apart easily with this guide. Just need a note on the small ball bearing which I assume goes somewhere on the steam valve?
Step - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 118
All Time: 2,784
