Rowenta Focus Heating Element and Soleplate Replacement
  1. Rowenta Focus Heating Element and Soleplate Replacement, Power Assembly: step 1, image 1 of 2 Rowenta Focus Heating Element and Soleplate Replacement, Power Assembly: step 1, image 2 of 2
    • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
    • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
    Ask FixBot
  2. Rowenta Focus Heating Element and Soleplate Replacement: step 2, image 1 of 3 Rowenta Focus Heating Element and Soleplate Replacement: step 2, image 2 of 3 Rowenta Focus Heating Element and Soleplate Replacement: step 2, image 3 of 3
    • Pry the back cover of the iron off using a metal spudger.
    • Remove the back cover, exposing the wiring in the iron.
    Ask FixBot
  3. Rowenta Focus Heating Element and Soleplate Replacement: step 3, image 1 of 2 Rowenta Focus Heating Element and Soleplate Replacement: step 3, image 2 of 2
    • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
    • Leave the other cords attached to the main cord.
    Ask FixBot
  4. Rowenta Focus Heating Element and Soleplate Replacement: step 4, image 1 of 2 Rowenta Focus Heating Element and Soleplate Replacement: step 4, image 2 of 2
    • Pull out the motherboard inside handle of iron.
    • Keep it attached to main power cord and other components.
    Ask FixBot
  5. Rowenta Focus Heating Element and Soleplate Replacement: step 5, image 1 of 3 Rowenta Focus Heating Element and Soleplate Replacement: step 5, image 2 of 3 Rowenta Focus Heating Element and Soleplate Replacement: step 5, image 3 of 3
    • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
    Ask FixBot
  6. Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: step 6, image 1 of 3 Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: step 6, image 2 of 3 Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: step 6, image 3 of 3
    • Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
    • Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
    • Lift out the piece.
    Ask FixBot
  7. Rowenta Focus Heating Element and Soleplate Replacement: step 7, image 1 of 3 Rowenta Focus Heating Element and Soleplate Replacement: step 7, image 2 of 3 Rowenta Focus Heating Element and Soleplate Replacement: step 7, image 3 of 3
    • Replace with an identical part by inserting it into the space.
    Ask FixBot
  8. Rowenta Focus Heating Element and Soleplate Replacement, Heating Element/Soleplate: step 8, image 1 of 2 Rowenta Focus Heating Element and Soleplate Replacement, Heating Element/Soleplate: step 8, image 2 of 2
    • Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
    Ask FixBot
  9. Rowenta Focus Heating Element and Soleplate Replacement: step 9, image 1 of 2 Rowenta Focus Heating Element and Soleplate Replacement: step 9, image 2 of 2
    • Unhook the clips on the top of the metal piece.
    • Using the metal spudger, remove the metal piece on the tip of the iron.
    Ask FixBot
  10. Rowenta Focus Heating Element and Soleplate Replacement: step 10, image 1 of 2 Rowenta Focus Heating Element and Soleplate Replacement: step 10, image 2 of 2
    • Using the T20 screwdriver, remove the 20 mm screw that was under the metal piece on the tip of the iron.
    Ask FixBot
  11. Rowenta Focus Heating Element and Soleplate Replacement: step 11, image 1 of 3 Rowenta Focus Heating Element and Soleplate Replacement: step 11, image 2 of 3 Rowenta Focus Heating Element and Soleplate Replacement: step 11, image 3 of 3
    • Using the T20 screwdriver, remove the two 20 mm screws on either side of the back of the iron.
    Ask FixBot
  12. Rowenta Focus Heating Element and Soleplate Replacement: step 12, image 1 of 3 Rowenta Focus Heating Element and Soleplate Replacement: step 12, image 2 of 3 Rowenta Focus Heating Element and Soleplate Replacement: step 12, image 3 of 3
    • Lift the iron up using the handle to completely detach the soleplate.
    Ask FixBot
4 other people completed this guide.
1 Guide Comment
hi how do i clean sole plate inside ??????????????????? wath sort of sealent do they use to seal it or where do you get it from????????????????
Willie Waldner - Reply Share
Past 24 Hours: 8
Past 7 Days: 49
Past 30 Days: 213
All Time: 6,934
