Up to 20% off select tools
Rotor Riot Face Button Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
71
All Time:
651
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the face buttons on your Rotor Riot controller.
    1. Rotor Riot Face Button Replacement, Remove the iPhone mount: step 1, image 1 of 3 Rotor Riot Face Button Replacement, Remove the iPhone mount: step 1, image 2 of 3 Rotor Riot Face Button Replacement, Remove the iPhone mount: step 1, image 3 of 3
      • Use your fingers to remove the screw on the back side of the controller securing the iPhone mount.
      • Remove the iPhone mount.
      Ask FixBot
    2. Rotor Riot Face Button Replacement, Unscrew the back cover: step 2, image 1 of 1
      • Use a T6 Torx screwdriver to remove the eight 9.2 mm-long screws securing the back cover.
      • Don't try to remove the back cover all the way yet! It's still connected to the mainboard.
      Ask FixBot
    3. Rotor Riot Face Button Replacement, Swing open the back cover: step 3, image 1 of 3 Rotor Riot Face Button Replacement, Swing open the back cover: step 3, image 2 of 3 Rotor Riot Face Button Replacement, Swing open the back cover: step 3, image 3 of 3
      • Lift up the back cover of the controller.
      • Lift the back cover to a 45 degree angle and place it next to the controller.
      • Don't strain the interconnect cable during this procedure.
      Ask FixBot
    4. Rotor Riot Face Button Replacement, Disconnect the phone connector cable: step 4, image 1 of 3 Rotor Riot Face Button Replacement, Disconnect the phone connector cable: step 4, image 2 of 3 Rotor Riot Face Button Replacement, Disconnect the phone connector cable: step 4, image 3 of 3
      • Use a spudger to disconnect the phone connector cable from the mainboard.
      Ask FixBot
    5. Rotor Riot Face Button Replacement, Remove the back cover: step 5, image 1 of 1
      • Remove the back cover.
      Ask FixBot
    1. Rotor Riot Face Button Replacement, Remove the shoulder buttons: step 6, image 1 of 2 Rotor Riot Face Button Replacement, Remove the shoulder buttons: step 6, image 2 of 2
      • Remove the shoulder buttons by lifting them out of the case.
      Ask FixBot
    2. Rotor Riot Face Button Replacement, Unscrew the mainboard: step 7, image 1 of 1
      • Use a Phillips screwdriver to remove the four 7.0 mm-long screws securing the mainboard.
      Ask FixBot
    3. Rotor Riot Face Button Replacement, Flip over the mainboard: step 8, image 1 of 3 Rotor Riot Face Button Replacement, Flip over the mainboard: step 8, image 2 of 3 Rotor Riot Face Button Replacement, Flip over the mainboard: step 8, image 3 of 3
      • Flip over the mainboard and place it above the controller housing.
      • Avoid tensioning the trigger button cables during this procedure and don't try to remove the mainboard all the way yet! It is still connected to the controller housing.
      Ask FixBot
    4. Rotor Riot Face Button Replacement, Remove the face buttons: step 9, image 1 of 2 Rotor Riot Face Button Replacement, Remove the face buttons: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the face buttons from the housing.
      • The alignment pegs on each button are designed to prevent incorrect installation. Make sure your new buttons fit properly in the controller case.
      Ask FixBot
Author
with
Adriana Zwink
69,920 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 71
All Time: 651
