Rosewill NEON M62 Side Buttons Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
48
All Time:
374
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 8 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This is a guide explaining how to take the side buttons on the Rosewill NEON M62 mouse off. This repair should be performed if the side buttons to the mouse are visually broken or the bottoms do not respond when clicked.
Tools
    1. Rosewill NEON M62 Side Buttons Replacement, Bottom Panel: step 1, image 1 of 1
      • Place the mouse so the bottom is facing upwards.
      • Remove the plastic skates.
      • These are not shown in the picture since they were missing from the device.
      • Remove the two 5 mm screws with a Phillips #00 screwdriver.
      Ask FixBot
    2. Rosewill NEON M62 Side Buttons Replacement: step 2, image 1 of 1
      • Use the opening tool along the side of the mouse to open up it.
      • This may take multiple attempts to do so; be patient and careful not to break the mouse.
      Ask FixBot
    3. Rosewill NEON M62 Side Buttons Replacement: step 3, image 1 of 2 Rosewill NEON M62 Side Buttons Replacement: step 3, image 2 of 2
      • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
      Ask FixBot
    1. Rosewill NEON M62 Side Buttons Replacement, Top Cover: step 4, image 1 of 2 Rosewill NEON M62 Side Buttons Replacement, Top Cover: step 4, image 2 of 2
      • Hold the top half of the mouse with your non-dominant hand.
      • With your dominant hand, push an opening tool into the gaps in the panel.
      • Pry the panel off.
      Ask FixBot
    1. Rosewill NEON M62 Side Buttons Replacement, Side Buttons: step 5, image 1 of 1
      • Using the opening tool, take the mouse 1 and mouse 2 buttons off the top of the mouse.
      Ask FixBot
    2. Rosewill NEON M62 Side Buttons Replacement: step 6, image 1 of 1
      • Remove the mouse 1 and mouse 2 buttons.
      Ask FixBot
    3. Rosewill NEON M62 Side Buttons Replacement: step 7, image 1 of 1
      • Place the mouse on its back.
      Ask FixBot
    4. Rosewill NEON M62 Side Buttons Replacement: step 8, image 1 of 1
      • Move around the mouse piece with an opening tool, and loosen up the piece.
      Ask FixBot
    5. Rosewill NEON M62 Side Buttons Replacement: step 9, image 1 of 1
      • Grab the mouse piece and take it out.
      Ask FixBot
    6. Rosewill NEON M62 Side Buttons Replacement: step 10, image 1 of 1
      • You're now ready to replace the side buttons.
      Ask FixBot
Sean Turk
217 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 48
All Time: 374
