Roper Dryer Belt Replacement
Video Guide
This guide was transcribed from a YouTube video.
      • Unplug the dryer from the wall, or turn off the breaker supplying the dryer.
      • WARNING: Electric dryers use 240 V power, so don’t work on the dryer while it’s plugged in.
      • Caution: Wear work gloves because dryer sheet metal edges can be sharp.
      Ask FixBot
      • Pull the lint filter out of the top-right lint screen housing.
      • Use a Phillips screwdriver to remove the two screws located on the blower housing at the lint screen opening.
      • Reminder: Keep these two screws separate since they secure the lint screen vent to the top of the blower housing.
      Ask FixBot
      • Slide a putty knife under the front edge of the top panel to locate the spring clips.
      • Press inward with the putty knife to depress a clip while lifting up on the top panel.
      • Repeat for the other clip, and lift the top panel up.
      • A small flathead screwdriver can also depress the clips if a putty knife won’t reach.
      Ask FixBot
      • Locate the door switch harness on the right side of the front panel area.
      • Use a putty knife or a small flathead screwdriver to depress the locking tabs on both sides of the harness connector.
      • Pull the connector apart to uncouple the door switch harness.
      • Caution: Don’t pull on the wires, and don’t force the connector without releasing both side clips.
      Ask FixBot
      • Open the dryer door to access the mounting screws.
      • Use a 5/16 inch nut driver to remove the two screws inside the door opening that hold the front panel and door assembly in place.
      • Support the assembly as you remove the screws because it can tip forward and the drum may shift slightly.
      • Pull the front panel outward slightly, then lift the assembly straight up to remove it from the bulkhead arms.
      • Note the hook arrangement so you can seat the assembly correctly during reassembly.
      Ask FixBot
      • Look under the drum and note the belt routing and the idler pulley location if the belt is still installed.
      • Pull the idler pulley to relieve tension, then slip the belt off the pulley and motor.
      • Remove the belt from around the drum.
      • Take your time and keep fingers clear of the idler pulley pinch points.
      Ask FixBot
      • Leave the drum in place if you only want to replace the belt.
      • Lift up on the belt and use it as a handle to lift the drum out of the cabinet if you want to inspect or clean inside the dryer.
      • Inspect the roller wheels, the idler pulley, and the motor while the drum is out.
      • Clean out dust and lint while the cabinet is open if needed.
      Ask FixBot
      • Use the belt to lift the drum and set the drum onto the rear bulkhead supports if you removed it.
      • Caution: The drum can slide off the rear support, so keep one hand on the drum while positioning it.
      • Slide the new belt over the drum with the grooved side of the belt facing the drum.
      • Use the old belt wear pattern on the drum as a reference for where the new belt should sit.
      Ask FixBot
      • Move the idler pulley toward the motor while threading the belt under the idler pulley and onto the motor shaft.
      • Try again if needed until the belt seats correctly on the motor and idler pulley.
      • Spin the drum by hand and confirm the belt tracks smoothly on the pulley and motor shaft.
      Ask FixBot
      • Set the bottom of the dryer door onto the hooks and align the door onto the bulkhead arms.
      • Spin the drum by hand to help the drum seat properly on the door bulkhead if alignment is difficult.
      • Use a 5/16 inch nut driver to reinstall the two screws inside the door opening.
      • Reconnect the door switch harness on the right side, and make sure both side clips lock in place.
      Ask FixBot
      • Lower the top panel and press down until the clips snap into place.
      • Use a Phillips screwdriver to reinstall the two screws at the lint screen vent opening that secure the dryer to the top of the blower housing.
      • Reinstall the lint filter.
      Ask FixBot
A correctly installed belt will turn as the drum spins by hand, and the door switch harness will be fully seated and locked. If the drum rubs or feels misaligned, reseat the drum on the rear bulkhead support and realign the door bulkhead before running the dryer. Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
7,134 Reputation
224 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 32
Past 30 Days: 168
All Time: 800
