Roland TR-505 Switch-board Replacement
  1. Roland TR-505 Switch-board Replacement, Removing the dials: step 1, image 1 of 3 Roland TR-505 Switch-board Replacement, Removing the dials: step 1, image 2 of 3 Roland TR-505 Switch-board Replacement, Removing the dials: step 1, image 3 of 3
    • With the dials in front of you carefully pull them up and away from the hide and shaft
    Ask FixBot
  2. Roland TR-505 Switch-board Replacement, Removing the bottom screws: step 2, image 1 of 1
    • Remove these Philips PH1 screw
    • Not all screws are the same,make sure to keep them organised:-)
    Ask FixBot
  3. Roland TR-505 Switch-board Replacement, Opening the device: step 3, image 1 of 2 Roland TR-505 Switch-board Replacement, Opening the device: step 3, image 2 of 2
    • Carefully separate the 2 half’s
    • If it’s not coming apart you may need a plastic pry tool to assist you
    • Once separated:with the ports facing you open the device like a book with the top panel lifted up slightly,make sure to open it to the right
    Ask FixBot
  4. Roland TR-505 Switch-board Replacement, Unplugging the connectors: step 4, image 1 of 1
    • Carefully unplug the connectors from their sockets by pulling on the tabs that stick out from the cable
    • Do not pull on the cable itself as you risk pulling the cables out of the connector
    Ask FixBot
  5. Roland TR-505 Switch-board Replacement, Disassembling the top half: step 5, image 1 of 1
    • with the connectors disconnected you can lift the top half away.
    • to take the switchboard off take out these PH 1 Philips screws
    • Thumbs up to Roland for adding arrows to where the screws are on the switch-board:-)
    Ask FixBot
  6. Roland TR-505 Switch-board Replacement, Removing the Switch-board: step 6, image 1 of 1
    • Carefully lift the switch-board out
    Ask FixBot
HelloMacOS
27,522 Reputation
11 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
38 Members
1,676 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 24
All Time: 347
