Roland KR-33 Iron Filaments Replacement
    1. Roland KR-33 Iron Filaments Replacement, Iron Filaments: step 1, image 1 of 2 Roland KR-33 Iron Filaments Replacement, Iron Filaments: step 1, image 2 of 2
      • Place the keyboard on its base and identify the loose key.
      • Loose keys will typically sag as shown in the photo.
      Ask FixBot
    2. Roland KR-33 Iron Filaments Replacement: step 2, image 1 of 2 Roland KR-33 Iron Filaments Replacement: step 2, image 2 of 2
      • Flip over the piano and take out the screws on the black strip with a Phillips #1 screwdriver.
      Ask FixBot
    3. Roland KR-33 Iron Filaments Replacement: step 3, image 1 of 2 Roland KR-33 Iron Filaments Replacement: step 3, image 2 of 2
      • Flip the keyboard back on its base and raise the top of the keyboard to see the loose key.
      Ask FixBot
    4. Roland KR-33 Iron Filaments Replacement: step 4, image 1 of 3 Roland KR-33 Iron Filaments Replacement: step 4, image 2 of 3 Roland KR-33 Iron Filaments Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Pick up the loose key and place it aside.
      • Pull out the iron filament below the key as well. It may be helpful to use tweezers to get it out if it is stuck.
      Ask FixBot
    5. Roland KR-33 Iron Filaments Replacement: step 5, image 1 of 3 Roland KR-33 Iron Filaments Replacement: step 5, image 2 of 3 Roland KR-33 Iron Filaments Replacement: step 5, image 3 of 3
      • Once you have the iron filament in hand place it on the open slot in the keyboard.
      • Place the white key that you placed aside on top of it and press down until you feel it lock in place.
      • Repeat steps 4-5 to fix any other keys that are loose.
      Ask FixBot
To reassemble your device, follow these directions in reverse and re insert all screws.
Leland Summers
121 Reputation
1 Guide authored
1 Guide Comment
My Roland KR 33 is missing keys. Needs repair. Contact info?
Nanette Kaufmann - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 831
