Roku XD 2050X Remote IR LED Replacement
    1. Roku XD 2050X Remote IR LED Replacement, Remote Control Casing: step 1, image 1 of 2 Roku XD 2050X Remote IR LED Replacement, Remote Control Casing: step 1, image 2 of 2
      • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
      • Remove the battery cover.
      • Remove the two AA batteries.
      Ask FixBot
    2. Roku XD 2050X Remote IR LED Replacement: step 2, image 1 of 2 Roku XD 2050X Remote IR LED Replacement: step 2, image 2 of 2
      • Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
      • Gently twist the spudger to separate the top and bottom halves of the remote.
      Ask FixBot
    3. Roku XD 2050X Remote IR LED Replacement: step 3, image 1 of 1
      • Gently use the spudger to pry the circuit board loose.
      Ask FixBot
    4. Roku XD 2050X Remote IR LED Replacement: step 4, image 1 of 1
      • Using either end of the spudger, gently lift and remove the clear keypad backing.
      Ask FixBot
    5. Roku XD 2050X Remote IR LED Replacement: step 5, image 1 of 1
      • Using either end of the spudger, lift and remove the rubber keypad.
      Ask FixBot
    1. Roku XD 2050X Remote IR LED Replacement, Remote IR LED: step 6, image 1 of 1
      • Desolder the two contacts for the IR LED.
      • Remove the IR LED from the circuit board.
      • For help with soldering view the ifixit soldering guide.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 24
All Time: 1,230
