Roku XD 2050X Remote Control Casing Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Roku XD 2050X Remote Control Casing Replacement, Remote Control Casing: step 1, image 1 of 2 Roku XD 2050X Remote Control Casing Replacement, Remote Control Casing: step 1, image 2 of 2
      • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
      • Remove the battery cover.
      • Remove the two AA batteries.
      Ask FixBot
    2. Roku XD 2050X Remote Control Casing Replacement: step 2, image 1 of 2 Roku XD 2050X Remote Control Casing Replacement: step 2, image 2 of 2
      • Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
      • Gently twist the spudger to separate the top and bottom halves of the remote.
      Ask FixBot
    3. Roku XD 2050X Remote Control Casing Replacement: step 3, image 1 of 1
      • Gently use the spudger to pry the circuit board loose.
      Ask FixBot
    4. Roku XD 2050X Remote Control Casing Replacement: step 4, image 1 of 1
      • Using either end of the spudger, gently lift and remove the clear keypad backing.
      Ask FixBot
    5. Roku XD 2050X Remote Control Casing Replacement: step 5, image 1 of 1
      • Using either end of the spudger, lift and remove the rubber keypad.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 966
