Roku Streaming Stick Macro Button Contacts Replacement
    1. Roku Streaming Stick Macro Button Contacts Replacement, Macro Button Contacts: step 1, image 1 of 1
      • Place the remote so that the battery cover is facing upwards.
      Ask FixBot
    2. Roku Streaming Stick Macro Button Contacts Replacement: step 2, image 1 of 1
      • Remove the battery cover to expose the battery compartment.
      Ask FixBot
    3. Roku Streaming Stick Macro Button Contacts Replacement: step 3, image 1 of 1
      • Remove batteries.
      Ask FixBot
    4. Roku Streaming Stick Macro Button Contacts Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the 1.5 mm wide screw.
      Ask FixBot
    5. Roku Streaming Stick Macro Button Contacts Replacement: step 5, image 1 of 2 Roku Streaming Stick Macro Button Contacts Replacement: step 5, image 2 of 2
      • Use a plastic opening tool to gently pry apart the plastic enclosure. Make sure you create a large enough gap before you attempt to separate the two pieces.
      Ask FixBot
    6. Roku Streaming Stick Macro Button Contacts Replacement: step 6, image 1 of 1
      • Gently remove the circuit board or motherboard.
      Ask FixBot
    7. Roku Streaming Stick Macro Button Contacts Replacement: step 7, image 1 of 1
      • First, gently remove the three plastic sheets. Then, remove the button panels from the remote control.
      • Repair the contact sheet as noted on the Button Contact Repair Kit listed above. Otherwise replace with new conductive button contacts.
      Ask FixBot
Feliciano Bandazi
145 Reputation
1 Guide authored
IUPUI, Team S2-G2, Wilson Spring 2018 Member of IUPUI, Team S2-G2, Wilson Spring 2018
IUPUI-WILSON-S18S2G2
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 4,088
