Roku 4 Ethernet Port Replacement
    1. Roku 4 Ethernet Port Replacement, Motherboard: step 1, image 1 of 1
      • Place the Roku 4 face-down on a table. The rubber sticker should be facing you.
      Ask FixBot
    2. Roku 4 Ethernet Port Replacement: step 2, image 1 of 1
      • Starting at one corner of the device, pull the rubber sticker back toward the opposite corner of the device carefully to reveal the underlying screws.
      • Completely remove the rubber sticker to reveal the underlying screws on the device.
      • Place the rubber sticker facing up on the table to preserve its adhesiveness. It will be needed to reassemble the device.
      Ask FixBot
    3. Roku 4 Ethernet Port Replacement: step 3, image 1 of 1
      • Turn the Phillips PH1 screwdriver counterclockwise to unscrew all 4 of the 12.0 mm screws.
      • Store the screws in a safe place, such as on a magnetic project mat, so they do not get lost before reassembly.
      Ask FixBot
    4. Roku 4 Ethernet Port Replacement: step 4, image 1 of 2 Roku 4 Ethernet Port Replacement: step 4, image 2 of 2
      • Turn the device over so you can see the "4" on the top cover.
      Ask FixBot
    5. Roku 4 Ethernet Port Replacement: step 5, image 1 of 2 Roku 4 Ethernet Port Replacement: step 5, image 2 of 2
      • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device and create a gap.
      • Prying open the device is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
      Ask FixBot
    6. Roku 4 Ethernet Port Replacement: step 6, image 1 of 1
      • After you have created a gap large enough to fit your fingers between, gently lift up the top cover to open the device and reveal the motherboard.
      • The motherboard should still be attached to the underside of the top cover by a red wire, a blue wire, and a black wire.
      Ask FixBot
    7. Roku 4 Ethernet Port Replacement: step 7, image 1 of 3 Roku 4 Ethernet Port Replacement: step 7, image 2 of 3 Roku 4 Ethernet Port Replacement: step 7, image 3 of 3
      • To begin removing the motherboard from the plastic casing, pinch the black plastic clip and gently pull upward.
      • Once you feel the motherboard begin to loosen from the plastic casing, pull it upward to remove it completely.
      Ask FixBot
    8. Roku 4 Ethernet Port Replacement: step 8, image 1 of 3 Roku 4 Ethernet Port Replacement: step 8, image 2 of 3 Roku 4 Ethernet Port Replacement: step 8, image 3 of 3
      • Peel back the black adhesive strip that attaches the blue wire to the motherboard.
      • Repeat this step for the strip that attaches the black and red wires to the motherboard.
      Ask FixBot
    9. Roku 4 Ethernet Port Replacement: step 9, image 1 of 3 Roku 4 Ethernet Port Replacement: step 9, image 2 of 3 Roku 4 Ethernet Port Replacement: step 9, image 3 of 3
      • Using a soldering iron, desolder the blue, red, and black wires from the motherboard.
      • Consult iFixit's Soldering Skills guide to safely use the soldering iron.
      • The motherboard should now be completely disconnected from the top cover of the device.
      Ask FixBot
    1. Roku 4 Ethernet Port Replacement, Ethernet Port: step 10, image 1 of 1
      • Lay the motherboard facedown on the table so you can see the large black ethernet port with several gold connections below it.
      • Use a soldering iron to desolder each of the ethernet port's connections to the motherboard.
      • Consult iFixit's Soldering Skills guide to learn how to safely use the soldering iron.
      Ask FixBot
    2. Roku 4 Ethernet Port Replacement: step 11, image 1 of 1
      • Using your thumb and pointer finger, carefully pinch the Ethernet port and pull it to the right, away from the motherboard, to remove it.
      Ask FixBot
Hank Harrison
476 Reputation
3 Guides authored
Baylor, Team S5-G4, Williams Spring 2017 Member of Baylor, Team S5-G4, Williams Spring 2017
BU-WILLIAMS-S17S5G4
3 Members
47 Guides authored
3 Guide Comments
Is that the HDMI port
cruzanbay45 - Reply Share
Is that the HDMI port on roku
where do you get the HDMI port for roku
mar plane - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 41
All Time: 1,651
