Roku 3 Remote Control Motherboard Replacement
Views: 6.1K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
105
All Time:
6,092
Comments: 7
3 comments on steps, 4 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If you have already tried restarting and re-pairing your remote and it is still not working, you may need to replace the motherboard.
Tools
    1. Roku 3 Remote Control Motherboard Replacement, Remote Control Battery: step 1, image 1 of 1
      • Flip the remote over so that the buttons are facing down and the end with the wrist strap is nearest your right hand.
      Ask FixBot
    2. Roku 3 Remote Control Motherboard Replacement: step 2, image 1 of 2 Roku 3 Remote Control Motherboard Replacement: step 2, image 2 of 2
      • Press and hold the black tab above the battery compartment.
      • While holding down the tab with your left hand, slide down the battery compartment cover with your right hand to remove it.
      Ask FixBot
    3. Roku 3 Remote Control Motherboard Replacement: step 3, image 1 of 1
      • Remove the batteries by placing a finger on one end of the battery and pushing downward while pulling the battery out.
      Ask FixBot
    1. Roku 3 Remote Control Motherboard Replacement, Remote Control Motherboard: step 4, image 1 of 2 Roku 3 Remote Control Motherboard Replacement, Remote Control Motherboard: step 4, image 2 of 2
      • Unscrew one 7 mm Phillips #0 screw from the center of the battery compartment.
      Ask FixBot
    2. Roku 3 Remote Control Motherboard Replacement: step 5, image 1 of 2 Roku 3 Remote Control Motherboard Replacement: step 5, image 2 of 2
      • Gently pry open the remote using the plastic opening tool.
      Ask FixBot
    3. Roku 3 Remote Control Motherboard Replacement: step 6, image 1 of 2 Roku 3 Remote Control Motherboard Replacement: step 6, image 2 of 2
      • The remote buttons, sensors, and motherboard are not attached to anything inside the remote. Take apart the remote with caution to ensure these components do not accidentally fall out.
      • Separate the top and bottom of the remote casing.
      • Gently place each half of the remote onto a table so that the exteriors are face down.
      Ask FixBot
    4. Roku 3 Remote Control Motherboard Replacement: step 7, image 1 of 1
      • Set aside the half of the remote with the buttons.
      • Take the the other half of the remote with one hand and remove the motherboard with your thumb and forefinger of the other hand.
      Ask FixBot
3 other people completed this guide.
Isobelle Espiritu
591 Reputation
3 Guides authored
Cal Poly, Team 15-2, Livingston Fall 2016 Member of Cal Poly, Team 15-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G2
3 Members
72 Guides authored
4 Guide Comments
Thanks for the tutorial. Any idea where I can buy the motherboard for the Roku 3 remote?
Bret Dennis - Reply Share
Where can I buy a Roku 3 remote motherboard replacement?
A. J. Sitarsky - Reply Share
Hi, wondered if you had any luck locating a motherboard for the Roku 3? Thanks!
Paul Cacioppo - Reply Share
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 105
All Time: 6,092
