Roku 3 Motherboard Replacement
Views: 6.4K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
93
All Time:
6,427
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
All individual parts can be replaced on the motherboard as well. Please see additional guides if needed.
    1. Roku 3 Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Place the Roku 3 on the table face down and orient it so you can correctly read the writing.
      Ask FixBot
    2. Roku 3 Motherboard Replacement: step 2, image 1 of 3 Roku 3 Motherboard Replacement: step 2, image 2 of 3 Roku 3 Motherboard Replacement: step 2, image 3 of 3
      • Pull back the rubber protection in the top right corner to locate the screw.
      • Repeat with the bottom right corner and bottom left corner.
      Ask FixBot
    3. Roku 3 Motherboard Replacement: step 3, image 1 of 1
      • Remove the 9 mm screws from the three corners with a Hex 1.3 Screwdriver.
      Ask FixBot
    4. Roku 3 Motherboard Replacement: step 4, image 1 of 2 Roku 3 Motherboard Replacement: step 4, image 2 of 2
      • Open the device by gently lifting the bottom half away from the top half of the device.
      Ask FixBot
    5. Roku 3 Motherboard Replacement: step 5, image 1 of 1
      • Use your fingers to carefully lift the motherboard from the top half of the device.
      Ask FixBot
    6. Roku 3 Motherboard Replacement: step 6, image 1 of 2 Roku 3 Motherboard Replacement: step 6, image 2 of 2
      • Pull away the IO shield from the motherboard using your hands.
      Ask FixBot
6 other people completed this guide.
Samantha Miller
290 Reputation
1 Guide authored
Cal Poly, Team 15-2, Livingston Fall 2016 Member of Cal Poly, Team 15-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G2
3 Members
72 Guides authored
3 Guide Comments
Buenas tardes exelente guía
Elias Herrera - Reply Share
06xcat - Reply Share
Great where to you get the motherboard?
Joseph Pigott - Reply Share
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 93
All Time: 6,427
