Roku 3 Ethernet Port Replacement
  1. Roku 3 Ethernet Port Replacement, Motherboard: step 1, image 1 of 1
    • Place the Roku 3 on the table face down and orient it so you can correctly read the writing.
    Ask FixBot
  2. Roku 3 Ethernet Port Replacement: step 2, image 1 of 3 Roku 3 Ethernet Port Replacement: step 2, image 2 of 3 Roku 3 Ethernet Port Replacement: step 2, image 3 of 3
    • Pull back the rubber protection in the top right corner to locate the screw.
    • Repeat with the bottom right corner and bottom left corner.
    Ask FixBot
  3. Roku 3 Ethernet Port Replacement: step 3, image 1 of 1
    • Remove the 9 mm screws from the three corners with a Hex 1.3 Screwdriver.
    Ask FixBot
  4. Roku 3 Ethernet Port Replacement: step 4, image 1 of 2 Roku 3 Ethernet Port Replacement: step 4, image 2 of 2
    • Open the device by gently lifting the bottom half away from the top half of the device.
    Ask FixBot
  5. Roku 3 Ethernet Port Replacement: step 5, image 1 of 1
    • Use your fingers to carefully lift the motherboard from the top half of the device.
    Ask FixBot
  6. Roku 3 Ethernet Port Replacement: step 6, image 1 of 2 Roku 3 Ethernet Port Replacement: step 6, image 2 of 2
    • Pull away the IO shield from the motherboard using your hands.
    Ask FixBot
  7. Roku 3 Ethernet Port Replacement, Ethernet Port: step 7, image 1 of 2 Roku 3 Ethernet Port Replacement, Ethernet Port: step 7, image 2 of 2
    • Turn over the motherboard so the back is face up and almost all large silver components are resting facedown on the table.
    • Orient it such that the backside of the HDMI port is in your upper right corner.
    Ask FixBot
  8. Roku 3 Ethernet Port Replacement: step 8, image 1 of 1
    • Desolder all of the port's connections with a soldering iron.
    • For more information on soldering, check out iFixit's Soldering Guide.
    Ask FixBot
  9. Roku 3 Ethernet Port Replacement: step 9, image 1 of 2 Roku 3 Ethernet Port Replacement: step 9, image 2 of 2
    • Locate the plastic push-throughs just to the left of the backside of the USB port.
    • Pinch the plastic push-throughs. The port should now be able to be removed.
    Ask FixBot
Andy Hak
268 Reputation
2 Guides authored
Cal Poly, Team 15-2, Livingston Fall 2016 Member of Cal Poly, Team 15-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G2
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 1,911
