Roconia Q6 Motherboard Replacement
  1. Roconia Q6 Motherboard Replacement, Top Cover: step 1, image 1 of 2 Roconia Q6 Motherboard Replacement, Top Cover: step 1, image 2 of 2
    • Flip your device upside down so that the interface is facing downwards.
    Ask FixBot
  2. Roconia Q6 Motherboard Replacement: step 2, image 1 of 3 Roconia Q6 Motherboard Replacement: step 2, image 2 of 3 Roconia Q6 Motherboard Replacement: step 2, image 3 of 3
    • The device is supported by rubber pieces located at the bottom extremities.
    • There are screws beneath the rubber pieces that can be removed. Remove all four 1.1 mm Phillips #1 screws by using the Phillips #0 screwdriver.
    Ask FixBot
  3. Roconia Q6 Motherboard Replacement: step 3, image 1 of 3 Roconia Q6 Motherboard Replacement: step 3, image 2 of 3 Roconia Q6 Motherboard Replacement: step 3, image 3 of 3
    • Turn device over again and pry open the device to remove the cover.
    Ask FixBot
  4. Roconia Q6 Motherboard Replacement: step 4, image 1 of 3 Roconia Q6 Motherboard Replacement: step 4, image 2 of 3 Roconia Q6 Motherboard Replacement: step 4, image 3 of 3
    • Pull out the cable that is connected to the top cover to fully separate.
    Ask FixBot
  5. Roconia Q6 Motherboard Replacement, Motherboard: step 5, image 1 of 3 Roconia Q6 Motherboard Replacement, Motherboard: step 5, image 2 of 3 Roconia Q6 Motherboard Replacement, Motherboard: step 5, image 3 of 3
    • Remove the 8.8mm screws holding the device in place using the Phillips #0 screwdriver.
    Ask FixBot
  6. Roconia Q6 Motherboard Replacement: step 6, image 1 of 2 Roconia Q6 Motherboard Replacement: step 6, image 2 of 2
    • Remove the wires attached to the motherboard by pulling them out gently.
    Ask FixBot
Axel
193 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 27
All Time: 324
