Roccat Tyon omron switch Replacement
Views: 6.4K
View statistics:
Past 24 Hours:
6
Past 7 Days:
36
Past 30 Days:
158
All Time:
6,361
Comments: 6
5 comments on steps, 1 guide comment.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
If your mouse start to register double-click when you click only once, this might be a worn switch.
Parts
Tools
    1. Roccat Tyon omron switch Replacement, uncovering the screws: step 1, image 1 of 3 Roccat Tyon omron switch Replacement, uncovering the screws: step 1, image 2 of 3 Roccat Tyon omron switch Replacement, uncovering the screws: step 1, image 3 of 3
      • All screw are hidden below the mouse
      • Peel off the mouse pad to uncover 5 of the 6 screws
      • The last screw is in a hole under the sticker. You don't need to remove the whole sticker to uncover it.
      Ask FixBot
    2. Roccat Tyon omron switch Replacement, remove the screws: step 2, image 1 of 2 Roccat Tyon omron switch Replacement, remove the screws: step 2, image 2 of 2
      • use the screwdriver to remove all the screws
      Ask FixBot
    3. Roccat Tyon omron switch Replacement, separate the top half: step 3, image 1 of 2 Roccat Tyon omron switch Replacement, separate the top half: step 3, image 2 of 2
      • Carefully remove the outer shell, the two halves are still connected by wires.
      • remove the white wire connector carefully
      Ask FixBot
    4. Roccat Tyon omron switch Replacement: step 4, image 1 of 3 Roccat Tyon omron switch Replacement: step 4, image 2 of 3 Roccat Tyon omron switch Replacement: step 4, image 3 of 3
      • unplug the remaining connectors
      • carefully pull-down the Ribbon cable to unplug it
      Ask FixBot
    5. Roccat Tyon omron switch Replacement, free the PCB: step 5, image 1 of 3 Roccat Tyon omron switch Replacement, free the PCB: step 5, image 2 of 3 Roccat Tyon omron switch Replacement, free the PCB: step 5, image 3 of 3
      • remove the last screws and pull the board free
      • the mouse wheel LED assembly is a separate piece you need to unscrew.
      Ask FixBot
    6. Roccat Tyon omron switch Replacement, remove the mouse wheel: step 6, image 1 of 2 Roccat Tyon omron switch Replacement, remove the mouse wheel: step 6, image 2 of 2
      • you need to pull the mouse wheel to the right to get it out
      Ask FixBot
    7. Roccat Tyon omron switch Replacement, remove the old omron switch: step 7, image 1 of 2 Roccat Tyon omron switch Replacement, remove the old omron switch: step 7, image 2 of 2
      • I want to change the left switch.
      • flip the board to unsolder the switch.
      • Only two legs are soldered, this is the third one
      Ask FixBot
    8. Roccat Tyon omron switch Replacement, solder the new switch: step 8, image 1 of 2 Roccat Tyon omron switch Replacement, solder the new switch: step 8, image 2 of 2
      • The new switch replace the old one not working.
      • The button should be on the left
      • I used a slightly different switch (D2FC-F-K(50M)). The official one is a D2FC-F-7N(RT)
      Ask FixBot
10 other people completed this guide.
marc balemboy
497 Reputation
1 Guide authored
1 Guide Comment
Greetings,
Would you happen to know the part number for the x-celerator paddle potentiometer replacement?
Thanks!
Enrique Rumbo - Reply Share
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 158
All Time: 6,361
