Up to 20% off select tools
Roborock S7 Right Wheel Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
36
All Time:
36
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This is in addition to the tear-down and sensor removal guide. Do this AFTER removing the sensor near the wheel.
    1. Roborock S7 Right Wheel Replacement, Remove Spring: step 1, image 1 of 1
      • Remove spring by carefully unhooking from the plastic hook. I used a small flathead screwdriver between some of the spring coils. Be sure to try this with the spring SLACKED (wheel not pushed in). Once unhooked, carefully pull out spring and set aside.
      Ask FixBot
    2. Roborock S7 Right Wheel Replacement, Disconnect Wiring: step 2, image 1 of 1
      • Carefully disconnect the motor ribbon cable from the motherboard. Unscrew single screw to release smaller board from housing. Gently untangle from wire canals; both cables show now be free.
      Ask FixBot
    3. Roborock S7 Right Wheel Replacement, Remove Wheel Pin: step 3, image 1 of 3 Roborock S7 Right Wheel Replacement, Remove Wheel Pin: step 3, image 2 of 3 Roborock S7 Right Wheel Replacement, Remove Wheel Pin: step 3, image 3 of 3
      • The pin holding in the wheel assembly should be visible (it's behind the cliff sensor so if you don't see it, go back and follow the guide to release this sensor closest to the wheel).
      • Push the pin from the opposite side, and work it through with a small flathead screw driver until you're able to freely pull it with your fingers.
      Ask FixBot
    4. Roborock S7 Right Wheel Replacement, Remove Wheel Assembly: step 4, image 1 of 1
      • You should now be able to pull it carefully from the machine. DONE!
      Ask FixBot
    5. Roborock S7 Right Wheel Replacement, BONUS - Inside the Wheel: step 5, image 1 of 2 Roborock S7 Right Wheel Replacement, BONUS - Inside the Wheel: step 5, image 2 of 2
      • You will most likely need to just purchase a replacement. After purchasing - opening up the assembly to try and fix or clean it is certainly possible. Unfortunately to fully remove the wheel from the assembly is pretty difficult. Recommend cleaning or replacement without this step but here's what the insides look like. Good luck!
      Ask FixBot
Rob Rogers
1 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 36
All Time: 36
