Roborock S5 Series Sidebrush Motor Replacement
    1. Roborock S5 Series Sidebrush Motor Replacement, Side Brush: step 1, image 1 of 2 Roborock S5 Series Sidebrush Motor Replacement, Side Brush: step 1, image 2 of 2
      • Power down your Roborock and place it upside down on a flat work surface.
      • Use a Phillips #2 screwdriver to loosen the captive screw holding the side brush in place.
      Ask FixBot
    2. Roborock S5 Series Sidebrush Motor Replacement: step 2, image 1 of 1
      • Gently lift the side brush away from the robot vacuum.
      Ask FixBot
    1. Roborock S5 Series Sidebrush Motor Replacement, Remove the bottom lid: step 3, image 1 of 1
      • Remove the 7 screws holding the bottom lid in place.
      • Lift off the bottom lid.
      Ask FixBot
    2. Roborock S5 Series Sidebrush Motor Replacement, Remove gearbox with motor: step 4, image 1 of 2 Roborock S5 Series Sidebrush Motor Replacement, Remove gearbox with motor: step 4, image 2 of 2
      • Remove the 3 screws holding the gearbox in place and lift it out.
      Ask FixBot
    3. Roborock S5 Series Sidebrush Motor Replacement, Open the gearbox: step 5, image 1 of 2 Roborock S5 Series Sidebrush Motor Replacement, Open the gearbox: step 5, image 2 of 2
      • Remove the 2 screws of the gearbox.
      • Carefully lift of the lid (try not to break the clip or loose the gears)
      • Pull the 2 white plastic gear wheels off to the top (potentially inspect those for damage while it's open anyway).
      Ask FixBot
    4. Roborock S5 Series Sidebrush Motor Replacement, Remove the motor: step 6, image 1 of 2 Roborock S5 Series Sidebrush Motor Replacement, Remove the motor: step 6, image 2 of 2
      • Check the orientation on the motor by looking at it from the back. Note the TP1 and TP2 markers on the PCB.
      • Remove 2 screws holding the motor in place.
      • Pull it off to the back.
      Ask FixBot
particleflux
139 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 129
All Time: 916
