Roborock Q5 Max Plus Side Brush Motor Replacement
  1. Roborock Q5 Max Plus Side Brush Motor Replacement, Side Brush: step 1, image 1 of 2 Roborock Q5 Max Plus Side Brush Motor Replacement, Side Brush: step 1, image 2 of 2
    • Carefully flip the Roborock upside down on a soft surface (e.g., towel) to avoid scratches.
    • Turn off the vacuum using the main switch underneath.
    Ask FixBot
  2. Roborock Q5 Max Plus Side Brush Motor Replacement: step 2, image 1 of 3 Roborock Q5 Max Plus Side Brush Motor Replacement: step 2, image 2 of 3 Roborock Q5 Max Plus Side Brush Motor Replacement: step 2, image 3 of 3
    • Hold down the side brush with one hand to prevent it from moving.
    • Use a Phillips #1 screwdriver to remove the single screw securing the side brush.
    • Remove it from the base.
    Ask FixBot
  3. Roborock Q5 Max Plus Side Brush Motor Replacement, Bottom Panel: step 3, image 1 of 2 Roborock Q5 Max Plus Side Brush Motor Replacement, Bottom Panel: step 3, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the eight 14 mm screws that secure the bottom shell.
    Ask FixBot
  4. Roborock Q5 Max Plus Side Brush Motor Replacement: step 4, image 1 of 1
    • Gently lift the the bottom shell up and off.
    • If you encounter resistance, double-check for any hidden screws that may have been overlooked.
    Ask FixBot
  5. Roborock Q5 Max Plus Side Brush Motor Replacement, Side Brush Motor: step 5, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the five screws that secure the side brush motor.
    Ask FixBot
  6. Roborock Q5 Max Plus Side Brush Motor Replacement: step 6, image 1 of 2 Roborock Q5 Max Plus Side Brush Motor Replacement: step 6, image 2 of 2
    • Carefully remove the side brush motor from its housing.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 47
All Time: 555
