Roborock Q5 Max Plus Brush Rolls Replacement
  1. Roborock Q5 Max Plus Brush Rolls Replacement, Bottom Panel: step 1, image 1 of 2 Roborock Q5 Max Plus Brush Rolls Replacement, Bottom Panel: step 1, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the eight 14 mm screws that secure the bottom shell.
  2. Roborock Q5 Max Plus Brush Rolls Replacement: step 2, image 1 of 1
    • Gently lift the the bottom shell up and off.
    • If you encounter resistance, double-check for any hidden screws that may have been overlooked.
  3. Roborock Q5 Max Plus Brush Rolls Replacement, Brush Rolls: step 3, image 1 of 1
    • Press the tabs on each side of the brush cover to remove it.
  4. Roborock Q5 Max Plus Brush Rolls Replacement: step 4, image 1 of 1
    • Lift the first brush roll out from its housing.
  5. Roborock Q5 Max Plus Brush Rolls Replacement: step 5, image 1 of 1
    • Lift the second brush roll out from its housing.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 226
