Up to 20% off select tools
Roborock Q5 Max Plus Bottom Shell Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
83
All Time:
750
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Over time, the bottom shell of the Roborock Q5 Max+ may need to be removed for cleaning, part replacement, or internal repairs. Whether you're replacing a damaged shell or accessing internal components like the battery, sensors, or wheels, this guide will walk you through the safe and effective removal and reinstallation process. This step-by-step guide ensures that even users with minimal repair experience can perform this procedure confidently.
    1. Roborock Q5 Max Plus Bottom Shell Replacement, Side Brush: step 1, image 1 of 2 Roborock Q5 Max Plus Bottom Shell Replacement, Side Brush: step 1, image 2 of 2
      • Carefully flip the Roborock upside down on a soft surface (e.g., towel) to avoid scratches.
      • Turn off the vacuum using the main switch underneath.
      Ask FixBot
    2. Roborock Q5 Max Plus Bottom Shell Replacement: step 2, image 1 of 3 Roborock Q5 Max Plus Bottom Shell Replacement: step 2, image 2 of 3 Roborock Q5 Max Plus Bottom Shell Replacement: step 2, image 3 of 3
      • Hold down the side brush with one hand to prevent it from moving.
      • Use a Phillips #1 screwdriver to remove the single screw securing the side brush.
      • Remove it from the base.
      Ask FixBot
    1. Roborock Q5 Max Plus Bottom Shell Replacement, Bottom Panel: step 3, image 1 of 2 Roborock Q5 Max Plus Bottom Shell Replacement, Bottom Panel: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the eight 14 mm screws that secure the bottom shell.
      Ask FixBot
    2. Roborock Q5 Max Plus Bottom Shell Replacement: step 4, image 1 of 1
      • Gently lift the the bottom shell up and off.
      • If you encounter resistance, double-check for any hidden screws that may have been overlooked.
      Ask FixBot
Author
with
Hector Borjas
188 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 83
All Time: 750
