Roborock Q5 Main Brush Housing Replacement
  1. Roborock Q5 Main Brush Housing Replacement, Side Brush: step 1, image 1 of 1
    • Power off your Roborock and place the device on a flat surface with the wheels facing up.
    • Position the robot so the five-pronged side brush is on the bottom right side.
    Ask FixBot
  2. Roborock Q5 Main Brush Housing Replacement: step 2, image 1 of 2 Roborock Q5 Main Brush Housing Replacement: step 2, image 2 of 2
    • Use a Phillips #2 screwdriver to loosen the single captive side brush screw.
    • The screw is attached to the side brush so they cannot be separated.
    Ask FixBot
  3. Roborock Q5 Main Brush Housing Replacement: step 3, image 1 of 2 Roborock Q5 Main Brush Housing Replacement: step 3, image 2 of 2
    • Lift the side brush up and off.
    Ask FixBot
  4. Roborock Q5 Main Brush Housing Replacement, Battery: step 4, image 1 of 3 Roborock Q5 Main Brush Housing Replacement, Battery: step 4, image 2 of 3 Roborock Q5 Main Brush Housing Replacement, Battery: step 4, image 3 of 3
    • Use a Phillips screwdriver to remove the seven 15 mm screws from the bottom panel.
    Ask FixBot
  5. Roborock Q5 Main Brush Housing Replacement: step 5, image 1 of 3 Roborock Q5 Main Brush Housing Replacement: step 5, image 2 of 3 Roborock Q5 Main Brush Housing Replacement: step 5, image 3 of 3
    • Gently lift off the bottom panel cover.
    • If the bottom panel is stuck, use a plastic spudger along the edges to gently lift it out of place, then remove it by hand.
    Ask FixBot
  6. Roborock Q5 Main Brush Housing Replacement: step 6, image 1 of 3 Roborock Q5 Main Brush Housing Replacement: step 6, image 2 of 3 Roborock Q5 Main Brush Housing Replacement: step 6, image 3 of 3
    • Use the two white straps to lift the battery out slightly to reveal the battery connector.
    • The battery is still connected to the robot vacuum. Take care not to strain the battery cable.
    Ask FixBot
  7. Roborock Q5 Main Brush Housing Replacement: step 7, image 1 of 3 Roborock Q5 Main Brush Housing Replacement: step 7, image 2 of 3 Roborock Q5 Main Brush Housing Replacement: step 7, image 3 of 3
    • Using moderate pressure, squeeze and pull on the four-wire connector to disconnect the battery from the robot vacuum.
    Ask FixBot
  8. Roborock Q5 Main Brush Housing Replacement, Main Brush Housing: step 8, image 1 of 3 Roborock Q5 Main Brush Housing Replacement, Main Brush Housing: step 8, image 2 of 3 Roborock Q5 Main Brush Housing Replacement, Main Brush Housing: step 8, image 3 of 3
    • Carefully flip the device and place it wheels down.
    • Pinch the dustbin tabs and pull up on the dustbin to remove it.
    Ask FixBot
  9. Roborock Q5 Main Brush Housing Replacement: step 9, image 1 of 3 Roborock Q5 Main Brush Housing Replacement: step 9, image 2 of 3 Roborock Q5 Main Brush Housing Replacement: step 9, image 3 of 3
    • Pull the plastic grommet off of the dust port.
    • If needed, use a spudger to help get underneath the lip.
    Ask FixBot
  10. Roborock Q5 Main Brush Housing Replacement: step 10, image 1 of 3 Roborock Q5 Main Brush Housing Replacement: step 10, image 2 of 3 Roborock Q5 Main Brush Housing Replacement: step 10, image 3 of 3
    • Carefully flip the device over and place it with the wheels up.
    • Push both of the gray retaining tabs toward each other and lift the cover on the main brush holder to remove it.
    • Grip and remove the main brush.
    Ask FixBot
  11. Roborock Q5 Main Brush Housing Replacement: step 11, image 1 of 2 Roborock Q5 Main Brush Housing Replacement: step 11, image 2 of 2
    • Use a Phillips screwdriver to remove the two 15 mm screws from the main brush housing.
    Ask FixBot
  12. Roborock Q5 Main Brush Housing Replacement: step 12, image 1 of 2 Roborock Q5 Main Brush Housing Replacement: step 12, image 2 of 2
    • Use a Phillips screwdriver to remove the three 15 mm screws that secure the main brush motor.
    Ask FixBot
  13. Roborock Q5 Main Brush Housing Replacement: step 13, image 1 of 2 Roborock Q5 Main Brush Housing Replacement: step 13, image 2 of 2
    • Remove the motor from its housing and lift the main brush housing out of the vacuum.
    Ask FixBot
Jon Panaro
366 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 136
All Time: 1,233
