Roborock Q5 Battery Replacement
    1. Roborock Q5 Battery Replacement, Side Brush: step 1, image 1 of 1
      • Power off your Roborock and place the device on a flat surface with the wheels facing up.
      • Position the robot so the five-pronged side brush is on the bottom right side.
      Ask FixBot
    2. Roborock Q5 Battery Replacement: step 2, image 1 of 2 Roborock Q5 Battery Replacement: step 2, image 2 of 2
      • Use a Phillips #2 screwdriver to loosen the single captive side brush screw.
      • The screw is attached to the side brush so they cannot be separated.
      Ask FixBot
    3. Roborock Q5 Battery Replacement: step 3, image 1 of 2 Roborock Q5 Battery Replacement: step 3, image 2 of 2
      • Lift the side brush up and off.
      Ask FixBot
    1. Roborock Q5 Battery Replacement, Battery: step 4, image 1 of 3 Roborock Q5 Battery Replacement, Battery: step 4, image 2 of 3 Roborock Q5 Battery Replacement, Battery: step 4, image 3 of 3
      • Use a Phillips screwdriver to remove the seven 15 mm screws from the bottom panel.
      Ask FixBot
    2. Roborock Q5 Battery Replacement: step 5, image 1 of 3 Roborock Q5 Battery Replacement: step 5, image 2 of 3 Roborock Q5 Battery Replacement: step 5, image 3 of 3
      • Gently lift off the bottom panel cover.
      • If the bottom panel is stuck, use a plastic spudger along the edges to gently lift it out of place, then remove it by hand.
      Ask FixBot
    3. Roborock Q5 Battery Replacement: step 6, image 1 of 3 Roborock Q5 Battery Replacement: step 6, image 2 of 3 Roborock Q5 Battery Replacement: step 6, image 3 of 3
      • Use the two white straps to lift the battery out slightly to reveal the battery connector.
      • The battery is still connected to the robot vacuum. Take care not to strain the battery cable.
      Ask FixBot
    4. Roborock Q5 Battery Replacement: step 7, image 1 of 3 Roborock Q5 Battery Replacement: step 7, image 2 of 3 Roborock Q5 Battery Replacement: step 7, image 3 of 3
      • Using moderate pressure, squeeze and pull on the four-wire connector to disconnect the battery from the robot vacuum.
      Ask FixBot
Joyce T
319 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 153
All Time: 2,003
