Introduction
This guide will help you remove the power cord and requires the use of a soldering iron. Check out this soldering guide for help if you don't know how to solder.
Twist the plastic lid counterclockwise to unlock it.
Lift the lid to remove it from the container.
Using a soldering kit, remove the solder for the black power cord from the circuit board.
Follow this soldering guide if you need extra help!
