Rival Mini Chopper MC-67BL Motor Replacement
    1. Rival Mini Chopper MC-67BL Motor Replacement, Turning Gears: step 1, image 1 of 2 Rival Mini Chopper MC-67BL Motor Replacement, Turning Gears: step 1, image 2 of 2
      • Twist the plastic lid counterclockwise to unlock it.
      • Lift the lid to remove it from the container.
      Ask FixBot
    2. Rival Mini Chopper MC-67BL Motor Replacement: step 2, image 1 of 1
      • Carefully remove the blade from the container.
      • For reassembly, the teeth on the metal shaft line up with slots on the inside of the plastic hole.
      Ask FixBot
    3. Rival Mini Chopper MC-67BL Motor Replacement: step 3, image 1 of 1
      • With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
      Ask FixBot
    4. Rival Mini Chopper MC-67BL Motor Replacement: step 4, image 1 of 1
      • Use your fingers to pry out the two rubber feet from the bottom cover of the base.
      • The two feet furthest from the button tower contain screws. The other two feet do not.
      Ask FixBot
    5. Rival Mini Chopper MC-67BL Motor Replacement: step 5, image 1 of 2 Rival Mini Chopper MC-67BL Motor Replacement: step 5, image 2 of 2
      • Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
      • Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
      Ask FixBot
    6. Rival Mini Chopper MC-67BL Motor Replacement: step 6, image 1 of 1
      • Firmly lift the bottom cover off of the base.
      Ask FixBot
    7. Rival Mini Chopper MC-67BL Motor Replacement: step 7, image 1 of 1
      • Remove the smaller white gear by lifting it up with your hand.
      Ask FixBot
    8. Rival Mini Chopper MC-67BL Motor Replacement: step 8, image 1 of 3 Rival Mini Chopper MC-67BL Motor Replacement: step 8, image 2 of 3 Rival Mini Chopper MC-67BL Motor Replacement: step 8, image 3 of 3
      • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
      • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
      • Continue turning the gear until completely removed from the blade-shaft.
      Ask FixBot
    1. Rival Mini Chopper MC-67BL Motor Replacement, Motor: step 9, image 1 of 1
      • Pull the shaft from the base.
      • This will require a bit of force.
      Ask FixBot
    2. Rival Mini Chopper MC-67BL Motor Replacement: step 10, image 1 of 1
      • Use a Phillips #2 screwdriver and unscrew the two base screws.
      Ask FixBot
    3. Rival Mini Chopper MC-67BL Motor Replacement: step 11, image 1 of 1
      • Unwind the power cord from the base pegs.
      Ask FixBot
    4. Rival Mini Chopper MC-67BL Motor Replacement: step 12, image 1 of 2 Rival Mini Chopper MC-67BL Motor Replacement: step 12, image 2 of 2
      • Use the plastic opening tool to pry open the base from the main body.
      • These two plastic prongs are pressed fit into the base. It may take some effort to pry the base completely off.
      • Once freed, lift the base panel from the main body. The motor and power cable are connected to this panel.
      Ask FixBot
    5. Rival Mini Chopper MC-67BL Motor Replacement: step 13, image 1 of 1
      • Use a Phillips #2 screwdriver to remove the screws that attach the motor to the base.
      Ask FixBot
    6. Rival Mini Chopper MC-67BL Motor Replacement: step 14, image 1 of 1
      • Pull the power cord wires up from underneath the wire hook on the side of the motor.
      Ask FixBot
    7. Rival Mini Chopper MC-67BL Motor Replacement: step 15, image 1 of 2 Rival Mini Chopper MC-67BL Motor Replacement: step 15, image 2 of 2
      • Carefully cut into the black wire casing for both wires using a small knife, and peel away the black casing.
      • Only cut deep enough to remove the casing.
      • For reassembly you will need black electrical tape to keep the wires from being exposed.
      Ask FixBot
    8. Rival Mini Chopper MC-67BL Motor Replacement: step 16, image 1 of 1
      • Use a soldering kit to remove solder from the circuit board for the red wire.
      • Follow this soldering guide if you need extra help!
      Ask FixBot
    9. Rival Mini Chopper MC-67BL Motor Replacement: step 17, image 1 of 1
      • Use a small knife to cut the copper wires from the bracket holding the black wire and power cord together.
      • For reassembly the copper wires will need to be soldered together.
      Ask FixBot
    10. Rival Mini Chopper MC-67BL Motor Replacement: step 18, image 1 of 1
      • Use a Phillips #1 screwdriver to unscrew the single 4.76-mm screw from the motor base to finish removing the motor.
      Ask FixBot
3 other people completed this guide.
Roxanne
522 Reputation
4 Guides authored
Cal Poly, Team 4-29, Amido Fall 2013 Member of Cal Poly, Team 4-29, Amido Fall 2013
CPSU-AMIDO-F13S4G29
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 47
All Time: 4,065
